Electronics => Repair => Topic started by: Sam Cohen on January 16, 2018, 01:39:33 pm
Hi fellow hobbyist
This is my first post, I just recently discovered this site with its very useful info.
My name is Sam and I’m an electronic hobbyist who lives near Jerusalem Israel.
I recently bought an HP 8648C RF generator from a local scrap yard, I paid 100$ for it and I’m now trying to fix it.
It has a problem with its PS, I’ts not putting any DC on its outputs, other then the PS internally it looks clean and in decent condition.
I took the PS Out and hooked up resistor load to its output and try to power it in attempt to identify the problem, this was unsuccessful.
All the capacitors look OK (Using an ESR meter) and nothing seems burned.
Strangely I couldn’t find electrical schematic for this PS which is what makes locating the failure very difficult.
I did found some used original HP PS units on EBAY for 350$, for a 100$ purchased generator it seems a little ridiculous.
So I thought of maybe using a PS made by another vendor that has more or less the same voltage rating.
The original PS produces +5V, +15V, -15V and +38VDC, I have no idea what is the current drain on each of the voltages, I do know that most of the power is drawn by the 5VDC (the DC Cable uses multiple wires for the 5VDC).
I have a Meanwell PS that has all the voltages except the +38V.
It produces 11A on 5V, 2.5A on 15V and 0.5A on -15V.
My plan is to use an LM2587 Based circuit to generate ~1A 38VDC form the 5VDC.
Do you guys see a problem with going at this route?, do you have recommendation?.
Any other ideas are welcome..
BTW I plan of use this generator for general electronic repair.
Thank you
Shmulik
I think your idea is feasible. At least to power up the unit to identify if other parts of the generator are working properly, at the very least.
Since you are in general electronic repair, then you should also repair the switching power supply.
Unplug connector to mother board. Take out the board from the unit.
Check for any missing components on the board, power it up and measure the output voltages.
[remember to discharge capacitors before you touch the board again].
If you're getting no output at all (check with no load to and see if there are any phantom voltages), then check the primary side first. Check fuses, rectifiers, switching transistors exc.
Hi Armadilo and Cyberdragon
Thank you for your reply.
I did took the PS Out, no voltage on any of the outputs with and without Loads.
Fusses capacitors rectifiers looks OK above that its beyond my capabilities.
Any way I did hookup that meanwell PS that I have with the 38V DC to DC converter and vwalla!! It works!!.
I let it work for few hours and saw no signs of excessive heat nor did the voltage drop on any of the rails.
So for now im putting the old PS aside and im working on mounting the replacement unit in.
I did manage to check the generator functionality and everything seems to work fine.
Attached is a picture I took.
Thanks again
Sam
Make sure it's still calibrated since you changed the power unit.
I fixed one of the power supplies in an HP8648. I didn't take very good notes, but I can remember that the problem was a high value resistor, I think it was 470k \$\Omega\$
The resistor is part of the start up circuitry.
If you post a good picture of the board, I might be able to help.
Regards,
Jay_Diddy_B
Hi Jay
Ja_diddy_B: See attached picture of the Old PS unit.
Cyberdragon: why do you think calibration is affected by the PS Change?, i dont see any data bus or something sophisticated running between the PS and the generator Board.
Thx
Old thread, but +1, the 470k startup resistor is nested in behind the large power resistor by the main cap. Mine decided to simply not start, nothing burned, fuses intact. This resistor was open. Suggest larger wattage for long term reliability. Good luck!
+1! I repair some 8648 power supply.The 470k startup resistor is open. Good luck!
Since this seems to be a common problem. Let me document it a little better. I have taken my HP8647A apart to photograph the repair.
If you are working on these make sure that the main capacitor is discharged.
Overview
[attachimg=3]
The resistor R1 is indicated by the arrow.
[attachimg=1]
The resistor is hidden near the power resistor.
Details
[attachimg=2]
This is the solder side of the board showing the pads for the resistor.
Regards
Jay_Diddy_B
I recently scored a 8647A in very nice condition out of ebay (as a repair project). However, it looks like Q2 is missing in the PSU (which has been fully recapped btw). I seriously doubt it is in working condition but before troubleshooting it, I'd like to make sure it's at least complete :)
Would anyone happen to have a PSU in hand to snap a picture or maybe already know what are the references of Q2?
Thanks a lot!
Happy holidays!
Great to have this post.
My generator was fully working and all of a sudden it just will not turn. It turned out to the the resistor mentioned here which measured open out of circuit .
Thanks for the post.
