Hello everybody, I came across one monitor which I was told makes buzzing sounds (for which I assume are inverter transformers), and sometimes wouldn't turn on. I have to say, with monitor working, I couldn't replicate the buzzing sound after replacing the bad caps, practically all of them, but I am worried about dark spots on the board indicating really high mosfet temperatures. After an hour, the enclosed box with the board is extremely hot to the touch (the reason for bad caps, surely). The board dates back to 2006.
I was thinking whether mosfets Q5 and Q6 have degraded over time and their internal resistance has increased? Does replacing the mosfets with even lower Rds(on) could solve the issue or could there be another reason for such high temperatures? Could some asymmetry or something else I overlooked?
Thank you, any suggestion would be highly appreciated.
