What I meant was: What's the advantage over a HP 8561 or 8568? Apart from the fact they start at 50 Hz instead of 10 Hz.
Is there a specific field of applications for 10 Hz to 150 MHz? Or does the 3589 have some features necessary for a particular application that a 8561 doesn't?
Or were these devices just cheaper enough to get their own little niche in the market?
Btw. about the age of T&M-Equipment: Everything up to 1989 is cool, then the SMD Cap-Plague hits and doesn't leave until the early 2000s.
Plus the ASICs typically run quite hot.
So I try to avoid anything from the 90s
