I want to share my experience replacing HP transistor array 1821-0001 in 3456A on A30 board.
some time ago this part failed in my 3456A. Replaced it with 5pcs of 2N3904 and it worked for some time. This suggestion was found somewhere in someone's blog. After some time unit started to be unreliable. Had to turn on oscilloscope which means it is serious repair
using 2N3904, timing on TP1 and TP2 on A30 board is way off. Same with new set of 2N3904. Looks like it was working just with help of devil.
Quick experiment showed that SS9018 transistors is almost perfect fit. SS9011 fits good also.
Pictures shows signal timing of original 1821-0001 (from working unit), 2N3904, 1821-0001, SS9011 and SS9018
sorry for different horizontal time base. Was on hurry.
Hope it saves someones day
