Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
HP Z800 RTC stops when powered off [SOLVED]
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: HP Z800 RTC stops when powered off [SOLVED] (Read 969 times)
perdrix
Frequent Contributor
Country:
on:
August 26, 2019, 11:29:09 am »
Start with the system running, and the clock set correctly. Shutdown/Power off. Come back later Power on and boot up. Clock shows same time as when I shut down!!!
Yes, I have replaced the CR2032 backup battery (the old one measured at 1.66V).
Has anyone seen this before?
I can't see any BIOS setting that would obviously cause this problem.
Suggestions most welcome!!! I'm about to remove the CR2032 and let it sit for a while.
Thanks
Last Edit: August 26, 2019, 02:00:44 pm by perdrix
Logged
perdrix
Country:
Re: HP Z800 RTC stops when powered off [SOLVED]
Reply #1 on:
August 26, 2019, 02:00:03 pm »
Ah well, all's well that ends well! Unplug, remove CMOS battery, press clear CMOS switch, replace battery, plug in again and set up BIOS from defaults seems to have fixed the problem!
D.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
