Author Topic: HP16716A not recognize as expander board  (Read 916 times)
Offline willycatTopic starter
« on: September 08, 2018, 05:52:46 pm »
I recently bought an HP16702A logic analyzer with 2 HP16716A boards on ebay. Used as standalone boards,  the boards pass all the selftests. Used as a two configuration boards, the expander board is not recognize (unknow board) and the selftests on the master board fail at "Inter-chip Resource Bus Test". Does someone already faced to this problem ?
Thanks,
willy.
Offline MarkL
Re: HP16716A not recognize as expander board
« Reply #1 on: September 09, 2018, 08:08:18 pm »
Assuming you have both the gray cable and the two flat-flex cables connected correctly, one thing you could try is to switch the roles of the two cards.  Sometimes just the master or the slave circuitry on one of them has failed.
There are many types of seemingly random failures for 167xx cards, but a large number are the result of corrosion underneath the plastic runners.  Over time, the adhesive HP/Agilent used attacks the traces and severs the connections.  The corrosion is visible as green crystals on the traces and vias around the runners.  If this is your problem, you can sometimes fix a card by removing the runners, cleaning the board, and bridging the damaged traces.
I've also seen severe corrosion on the bottom side flat flex connector contacts (again, as a result of the adhesive).  You can try cleaning or replacing the connectors if this is the case.
« Reply #2 on: September 10, 2018, 04:15:25 pm »
i tried the cards in two way: First with the expander on the master connected to J7. Then with the expander under the master connected to j5. I repeated each time by swapping the boards. And the result is the same: the expander is never recognize. I tested the cables and they are ok.
Here is the result of the failed self test (when slot c was the master):
Setting Result level
Result level set to 7
Testing Inter-chip Resource Bus Test
ICR Drive Test ...
  Slot C, Chip 9: RES Z,Y,X - exp: 0x5555,aaaa,5555  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xaaaa,5555,aaaa  actual: 0x0000,0000,0000
> Slot C, Chip 9: ICR Drive Test Failed!
  Slot C, Chip 8: RES Z,Y,X - exp: 0x5555,aaaa,5555  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xaaaa,5555,aaaa  actual: 0x0000,0000,0000
> Slot C, Chip 8: ICR Drive Test Failed!
ICR Walking Zeros Test ...
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,fffe  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,fffe  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,fffd  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,fffd  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,fffb  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,fffb  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,fff7  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,fff7  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,ffef  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,ffef  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,ffdf  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,ffdf  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,ffbf  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,ffbf  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,ff7f  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,ff7f  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,feff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,feff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,fdff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,fdff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,fbff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,fbff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,f7ff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,f7ff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,efff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,efff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,dfff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,dfff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,bfff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,bfff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffff,7fff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffff,7fff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,fffe,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,fffe,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,fffd,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,fffd,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,fffb,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,fffb,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,fff7,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,fff7,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffef,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffef,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffdf,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffdf,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ffbf,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ffbf,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,ff7f,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,ff7f,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,feff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,feff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,fdff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,fdff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,fbff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,fbff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,f7ff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,f7ff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,efff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,efff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,dfff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,dfff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,bfff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,bfff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffff,7fff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffff,7fff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xfffe,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xfffe,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xfffd,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xfffd,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xfffb,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xfffb,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xfff7,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xfff7,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffef,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffef,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffdf,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffdf,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xffbf,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xffbf,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xff7f,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xff7f,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xfeff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xfeff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xfdff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xfdff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xfbff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xfbff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xf7ff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xf7ff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xefff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xefff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xdfff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xdfff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0xbfff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0xbfff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 9: RES Z,Y,X - exp: 0x7fff,ffff,ffff  actual: 0x0000,0000,0000
  Slot C, Chip 8: RES Z,Y,X - exp: 0x7fff,ffff,ffff  actual: 0x0000,0000,0000
> Slot C, Chip 9: ICR Walking Zeros Test Failed!
> Slot C, Chip 8: ICR Walking Zeros Test Failed!
I completely removed the plastic runners because i saw on a thread on this forum that they cause corrosion. But i don't see critical damages: only a few vias have there solder paste became dull.
Is it possible that it lack a piece of software ?
Here is the result of the "pv" command:
pv> l
# Model 16702A
# System Memory=64 Mbytes, PCI device=3, PCI driver=1.01
Mod CPU: System CPU Board
Mod PCI: 16702A System PCI Board
Mod A  : Empty slot
Mod B  : (0x2e) 16716A 167MHz State/2GHz Timing Zoom 512K Sample
Mod C  : (0x2f) Unrecognized module
Mod D  : (0x21) 16550A 100MHz State/500MHz Timing Exp (master=E)
Mod E  : (0x20) 16550A 100MHz State/500MHz Timing
Mod 1  : Empty slot
Mod 2  : Empty slot
Module B 0x2e is the master and Module C 0x2f is the expander marked as Unrecognized module.
Here is the result of the "pcipeek" command:
rockyII> l
   A: id=0xff  Empty Slot
   B: id=0x2e  Unknown hardware ID
   C: id=0x2f  Unknown hardware ID
   D: id=0x21  16550A 100MHz State/500MHz Timing Expander
   E: id=0x20  16550A 100MHz State/500MHz Timing
   F: id=0xff  Empty Slot
   G: id=0xff  Empty Slot
   H: id=0xff  Empty Slot
   I: id=0xff  Empty Slot
   J: id=0xff  Empty Slot
   1: id=0xff  Empty Slot
   2: id=0xff  Empty Slot
   3: id=0xff  Empty Slot
   4: id=0xff  Empty Slot
I will post pictures of the boards.
Thanks.
Willy.
