Hi all,
Need some help again, just wanted to ask a question, whilst making the adjustment I accidentally adjusted A3C2 a .5v comp. I turned the pot a lot whilst my dmm was attached to the cal 1v which at the time was reading 0.448 volts and whilst moving the pot nothing changed on the dmm, then I realised that I should of been adjusting pot A3R116 to get the 0.5 volts which a I did. Now my question is what effect would of adjusting A3C2 have made, im worried as having checked the manual this is for attenuator compensation and to calibrate this pot you need an 10khz sine generator which i do not have.
Any advice pls thks.
