To post a Saturday morning update...
When I 1st got the meter, I replaced most of the electrolytic caps. A couple of the power filtering caps were cracked. (I meant to mention this in my initial post, clearly I did not...)
There are reports of the display connector's being fragile/easily broken. I'm a little nervous of going that direction (at least at the start).
I checked the CPU reset line (U501 pin 4). It was being held low. This reset line also connects to U512 pin 17. It seems to be driven from U550 pin's 1&2. This was also measured to be low.
I powered the meter off and did re-flow the negative solder joint for the battery.
I started poking about to document each of the pin values on U550. When I came across pins 1/2 again, they were high. And the meter was online.
U550 is a 1826-0138 - This is a NTE834 Voltage Comparator (
http://www.weisd.com/store2/NTE834.pdf).
I power cycled the meter, and it wouldn't start up again. I found through experimentation that simply probing pin 4 of U550, the meter would start up.
Page 7-F-17 of the service manual outlines the logic - U550 is supposed to hold the Reset line low until the voltage comes up on pin 4 - Once the voltage reaches a high enough level, it releases the RESET pin and allows the processor to process. I found there was no connection between pin 4 of U550 and R765 . For now I've installed a bodge wire between R765 and pin4 of U550.
I do not see any visible cracks/breaks in the PCB.
Many thanks to
MarkL for pointing me in the right direction.
Take a look at the processor nRESET (U501 pin 4). See if it's low (processor held in reset).
