Hi all, thought I'd share my solution for fixing the keyswitches on a HP 4145B Semiconductor Parameter Analyzer.
I've recently had the chance to acquire a HP 4145B for really cheap. It wasn't in the best of shapes: it was missing some bits (most notably everything in the way of cables/test fixtures), didn't have the system disk, and all I knew about it is that it would power up and spit an error about missing said disk.
Writing a system floppy disk was easy enough, thanks to a good Samaritan who uploaded an image of it somewhere, and with it the unit actually worked, except for the fact that its front panel keyboard had turned to crap. Most keys seemed stuck and pressing them wouldn't register anything.
I came across
this topic, with a video showing an easy repair for those switches, and I proceeded to take the front panel apart to try and implement the fix. In my case, however, most of the steel leaf springs that give the switch its bounciness were corroded, some to the point of disintegration, so no easy fix for me, I'd have to replace those springs instead of just poking at them like in the video.
It occurred to me, however, that instead of steel leaf springs, I could try using a plastic sheet of some description. I enlisted the help of a good friend and, after experimenting with a few different types of sheets, we settled on a transparency, of the kind used with overhead projectors. In about two hours' work (plus a pizza break) we cut acetate pieces to size and replaced all leaf springs, so we had a mostly working keyboard. There isn't as much tactile feedback as there would be with the original steel springs, but IMO it feels nice to the touch, if a bit mushy, and they definitely actuate easier than before. A few keys are still unresponsive, so I'll get in there with some contact cleaner later on.
Now to find them triaxial cables for a price that fits in my broke university student budget...
Edit: After copious amounts of contact cleaner and some wiggling, all keyswitches work properly
