Recently, I got an HP4262A LCR in the second-hand market. When I turned on the power after cleaning, I saw a flash from the back of the device!!! The fuse is blown! I can't replace the fuse immediately until I find the fault. So I looked up the service manual, found the circuit of the power supply part, and then opened the chassis. I found the junction box of the transformer's primary winding, and then welded it down to measure the resistance value of the primary winding. The resistance value measured by the two primary windings is too low, only a dozen ohms. It is obvious that there is a short circuit inside the transformer.
The only thing I can do is replace the transformer. It is difficult to find the same transformer in the second-hand market, so I decided to order a new one. But I can't find the details of this transformer in the circuit diagram of the manual. The secondary output voltage, current and rated power, etc. Do you know who has the HP4262A to help measure the output voltage of the transformer?
