Author Topic: HP5216A 12.5MHZ Counter Nixie Tubes  (Read 8736 times)
Online Johnny10
« on: July 17, 2016, 03:09:23 pm »
Just purchased this unit and wondering if anyone had a clearly readable schematic?
Downloaded the manual from the Keysight/Agilent site but it is unreadable.
I can make out text but not the schematic or parts list.
Thanks ahead of time,
« Last Edit: July 17, 2016, 07:41:20 pm by Johnny10 »
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, Fluke 181, uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP8568B
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
Re: HP5216A 12.5MHZ Counter Nixie Tubes
« Reply #1 on: July 17, 2016, 06:56:26 pm »
I'll do some digging later - I *might* have something on that.  The challenge, if I do, will be finding it.   |O
-Pat
Online Johnny10
« Reply #2 on: July 17, 2016, 07:56:38 pm »
Thanks Cubdriver !
I played with it a while this afternoon and now the 10 meg and 1 meg nixies have stopped displaying properly.
Second digit is stuck on 8 and first digit stays at zero.
Hope I am not burning out driver chips !!
« Last Edit: July 17, 2016, 07:58:42 pm by Johnny10 »
Offline Cubdriver
  • Nixie addict
« Reply #3 on: July 17, 2016, 08:31:47 pm »
I'm pretty sure that they're cascaded counters, so if the second from the left is somehow locked on 8, then it will never send a pulse to increment the extreme left one.
-Pat
Online Andy Watson
« Reply #4 on: July 17, 2016, 08:34:25 pm »
Hmmmmmmmm ... nixie porn!
If the digits are stuck the problem is more likely to be further down the chain than the drivers.
See if this helps:
http://cp.literature.agilent.com/litweb/pdf/05216-9006.pdf
Online Johnny10
« Reply #5 on: July 17, 2016, 08:44:42 pm »
Yep, that's the one I downloaded. Parts list and schematics are all distorted from scan.
And I did pull that bug out of the switch !!
They are so cool to look at !
That makes sense about the tube increment.
I sent  10-12 Mhz through and no change from zero.
« Last Edit: July 17, 2016, 09:12:32 pm by Johnny10 »
Offline Cubdriver
  • Nixie addict
« Reply #6 on: July 19, 2016, 06:28:05 am »
Ok, I found the op/service manual.  Of course it has a bunch of those three foot wide fold out schematics.  I'll try to do some scans tonight.  My first attempt didn't go well, as of course they're juuuuuust a little wider than three pages, so when I tried a three step scan a strip was missing form the schematic.  Perhaps I'll try taking a photo instead.
-Pat
Offline Cubdriver
  • Nixie addict
« Reply #7 on: July 19, 2016, 06:32:02 am »
Oh, and a quick check of evilbay shows a vendor selling the manual for $18.75 OBO with $4.22 shipping; you might be able to get it for $15-16 + shipping...
-Pat
Online Johnny10
« Reply #8 on: July 19, 2016, 12:44:25 pm »
Thank you for the time you spent.
I guess I will look to buy a manual.
Have had a lot of luck with Dave at Artek.
Wasn't sure what to do with this unit but the more I watch the nixie tubes spin and glow as it searches for frequency measurements...
maybe restore this unit?
It is in awful shape inside but it does partially function. Tubes are bright and it measures accurate frequency.
I did notice looking back at the first photo I took of display that the stuck nixie worked when I first turned the unit on.
This counter and the 2 other items I bought coming from same owner were sitting in a barn untouched for 20 years.
I picked up a Heathkit IT-28 and a Heathkit IM-11 and those also had a lot of bad mildew and droppings inside.
Online Johnny10
« Reply #9 on: July 19, 2016, 12:48:27 pm »
The interior shots.
Online Johnny10
« Reply #10 on: July 19, 2016, 01:29:28 pm »
Clock
Offline Towger
  • Country: ie
« Reply #11 on: July 19, 2016, 01:47:27 pm »
Those caps on the board to the right of the clock look fairly knackered.
Offline Cubdriver
  • Nixie addict
« Reply #12 on: July 19, 2016, 05:10:51 pm »
The Artek manual scans are fantastic, and I don't think you'll find better copies than those that Dave makes, but in my mind they still don't beat having the actual original HP paper manual in your hand.  The schematics are much easier to read as fold outs rather than either trying to scan back and forth on the computer screen, or trying to print out and tape together hard copies.  If I can't get a reasonably priced paper copy I definitely buy scans from Dave, but given the option between a PDF and original paper, IMO there's no contest.  (And I have bought about a half dozen of his scans, so I know their quality.)
Perhaps I'm old fashioned, but I still prefer reading things with pages that flip to images that scroll.  Especially when comparing things a few pages apart, it's far easier to me to hold the pages and flip back and forth as needed, or stick something in as a bookmark to rapidly get back.
As for your 'new' counter, I personally would definitely do my best to repair it, if for no other reason than it's a cool old piece of technology.  If it's been sitting unused in a barn for 20 years, I'd start by looking at power supply ripple.  HP used high quality caps, but they may be toast by now.  Cleaning the crud off of it would also help to eliminate any leakage paths that might be sending signals astray.
I would be happy to scan or photograph the schematics or sections thereof for you to get you started while you wait for an actual manual copy if you'd like.  The power supply isn't terribly big.
-Pat
Online Johnny10
« Reply #13 on: July 19, 2016, 06:15:33 pm »
As I have said I do have the Agilent copy of the manual but the parts list and schematics are impossible to read.
Last night I followed the Front Panel Troubleshooting guide and it suggests looking at A4Q8.
But I don't know where it is !! A4 Main board Transistor 8
Measured voltages across the power supply caps
9.75VDC    303mv AC
18.12 VDC   70.2mv AC
212 VDC     2.14V AC
Going to have to do a bit more reading.
I do agree with you Cubdriver about paper manuals.
While working on my Sencore LC102 I had to print out 8 pages and paste them all together to make the schematic.
Offline Cubdriver
  • Nixie addict
« Reply #14 on: July 19, 2016, 06:46:35 pm »
Main board layout(Q8 on left side near bottom, adjacent to IC 12):
Main part of schematic - Q8 near center:
Additional image showing left edge of page:
Not perfect, but I hope this helps.
-Pat
Online Johnny10
« Reply #15 on: July 19, 2016, 09:44:34 pm »
Thanks for going above and beyond !!!
Offline Cubdriver
  • Nixie addict
« Reply #16 on: July 19, 2016, 10:02:41 pm »
Happy to help!  I have a soft spot for nixie stuff.   :)
-Pat
Online Johnny10
« Reply #17 on: July 20, 2016, 01:28:06 pm »
OK. So I ordered the paper copy of manual.
Guess I will start cleaning up unit and start looking for specs of Capacitors to change in power supply.
Offline bitseeker
« Reply #18 on: September 08, 2016, 01:40:31 am »
Johnny10, how's your 5216 coming along? I've had a couple of these for a little while and Cubdriver was in the process of getting one.
I TEA.
Online Johnny10
« Reply #19 on: September 08, 2016, 01:15:47 pm »
I picked up the paper manual and am now waiting for the new caps to come in.
Funny you should bring that up this morning...  I was just reading the thread  "Let's see your nixie equipment" and thought hey this thing has to get back on the bench!
Will keep you up to date.
I will say it was very accurate before I took it all apart.
« Last Edit: September 08, 2016, 01:18:17 pm by Johnny10 »
Offline bitseeker
« Reply #20 on: September 08, 2016, 06:38:10 pm »
What a coincidence. We've gone from none of this model to several in the span of a few months. Looking forward to getting them all running well again.
I TEA.
Online Johnny10
« Reply #21 on: September 22, 2016, 02:50:09 pm »
Recapped the power supply.
Now have 172.3 VDC, 5.1 VDC, 5.65
Clock is accurate 1Mhz
2nd Pic shows 20K signal from my HP8903B
No luck with the driver circuit yet.
Starting to investigate stuck 6th digit today.
I get proper readings on display just not able to get proper display on 6th and 7th tubes
« Last Edit: September 25, 2016, 05:44:32 pm by Johnny10 »
Online Johnny10
« Reply #22 on: September 24, 2016, 01:09:50 pm »
Where do you buy the driver chips for this unit?
I found the 6th digit 1820-0119 chip is faulty.
It is outputting the bcd code for "8" no matter the input.
The 10x divider pin output lost output voltage also.
I see Sphere has some.
Any other recommendations ?
« Last Edit: September 24, 2016, 03:13:05 pm by Johnny10 »
Online Jwalling
  • This is work?
« Reply #23 on: September 24, 2016, 04:41:23 pm »
I would recommend Sphere.
Some here:
http://www.electronicsurplus.com/hewlett-packard-1820-0119-transistor-transistor-logic
But that price sucks. Does that part cross-ref to a JEDEC number?
Jay
System error. Strike any user to continue.
Offline bitseeker
« Reply #24 on: September 24, 2016, 04:48:26 pm »
Last month, there was a listing on eBay for a digit repair kit (used parts from HP counters). I thought I saw it originally listed for one set of components, but it looks like it was revised to be three kits (three complete sets) and the price adjusted, accordingly, before it sold. The kit contained the following:
HP 1820-0092 Integrated Circuit
HP 1820-0119 Integrated Circuit
HP 1820-0116 Integrated Circuit
HP 4 232 RCA Transistor
http://www.ebay.com/itm/322222800112
So, you might contact the seller to see if more are anticipated.
I TEA.
Online Johnny10
« Reply #25 on: September 24, 2016, 05:31:26 pm »
I will do that.
Also I have a HP5340 on the way for repair.
Yikes!
Offline Cubdriver
  • Nixie addict
« Reply #26 on: September 24, 2016, 10:54:07 pm »
I will do that.
Yikes!
And so it begins.....    :-DD :-DD :-DD >:D
-Pat
Offline bitseeker
« Reply #27 on: September 25, 2016, 01:57:00 am »
Yikes!
That it does. :popcorn:
I TEA.
Offline TheSteve
  • GHz
« Reply #28 on: September 25, 2016, 04:20:47 am »
I will do that.
Yikes!
So much hardware to enjoy, what is wrong with it?
VE7FM
Offline bitseeker
« Reply #29 on: September 25, 2016, 04:35:16 am »
Nothing wrong here. Johnny's joining the club. :-/O
I TEA.
Offline Cubdriver
  • Nixie addict
« Reply #30 on: September 25, 2016, 04:50:46 am »
Come to the orange glowie side - we have cookies!    ;)
-Pat
Online Johnny10
« Reply #31 on: September 25, 2016, 05:09:44 pm »
TheSteve, I don't know what problems on 5340.
I do know it is from first year 1973 !
I see you just bought one, we will have to compare when mine comes in next week.
I see the nixie tubes just keep multiplying. Have to watch out for that !
« Last Edit: September 26, 2016, 02:25:18 am by Johnny10 »
Offline TheSteve
  • GHz
« Reply #32 on: September 25, 2016, 11:44:53 pm »
Very nice, it is truly a first class machine. My 5340A works perfect but I am still considering a possible re-cap. I haven't looked in detail but it does smell a little of old capacitor when first turned on.
VE7FM
Offline TheSteve
  • GHz
« Reply #33 on: September 29, 2016, 03:56:42 am »
Replaced the 6 electrolytic power caps in my 5340A today - no more odor when it powers up. All of the original caps measure OK but they are clearly the source of the funk. Also one of them does show some signs of leakage near one of the terminals. Not enough to leave any kind of mark on the PCB.
Btw the caps all screw in to place - gold plated board and stainless steel hardware to bolt the caps in. You can still get replacements that screw in that are close in value but the cost is insane. So I opted to solder in some snap caps(1/5th the price) even though it hurt to solder to the gold PCB where the screws went. It had three voltage/capacitance values originally, I replaced them all with 50 volt 4700 uF.
When you do receive your 5340A I'd check the caps/power supply before connecting power.
VE7FM
Online Johnny10
« Reply #34 on: September 29, 2016, 11:48:00 am »
My unit should be here tomorrow or Monday.
Refurbished an old Heathkit Cap checker a few months ago that you couldn't stand the smell of the electrolytic capacitors.
Left them outside for a week and you could pick them up and still they smelled bad.
Does this unit have the same HP decoder and buffer storage IC's as the 5216A?
1820-0116 and 1820-0092.
Guess I am going to buy a parts unit rather than individual chips.
The best I have found are between 8-15 dollars without shipping.
I emailed the seller with 3 sets for $30 but those were his last ones.
Offline bitseeker
« Reply #35 on: September 29, 2016, 06:56:29 pm »
Solder the cap terminals to bolts (probably cut the heads off) and then install into the PCB?
I TEA.
Offline TheSteve
  • GHz
« Reply #36 on: September 29, 2016, 08:08:03 pm »
Too late, they got soldered in. On the plus side I ran the counter all night without any issues, it is still happily counting a sweeping input.
I had considered making a few PCB's that the snap caps would solder to that also had nuts soldered to them so they could be screwed in place. I would have also needed to make spacers so the caps were properly supported. In the end I accepted the soldering and am very happy with the results. I really want a whole stack of gear of a similar vintage now.
VE7FM
Offline Cubdriver
  • Nixie addict
« Reply #37 on: September 29, 2016, 09:26:15 pm »
<snip>
 :-DD :-DD
And another one bites the dust!   ;D  Welcome to the club!!
-Pat
Offline bitseeker
« Reply #38 on: September 30, 2016, 05:25:37 pm »
Yeah, I saw that the deed had been done, but was just thinking out loud in case someone else in a similar situation came along. It might even be something I'll have to do at some point. So, thanks for the conceptual confirmation.
I TEA.
Online Johnny10
« Reply #39 on: October 01, 2016, 12:07:23 am »
Although this thread was about the HP 5216A and it slowly started drifting towards the 5340A I will just say...
Received my new 5340A Option 001 unit today and all the nixies light and the 10-250mhz is working fine but when I plug into the rightmost input I get nothing.
000.0 .
Will have to check that out tomorrow.
I have read about the input limit and the irreversible damage it causes.
Will I be lucky or not?
Offline TheSteve
  • GHz
« Reply #40 on: October 01, 2016, 12:11:46 am »
000.0 .
Yeah, the 5340A drift is my fault - why not start a new thread for yours. There is far too little info on them on the forum right now anyway.
VE7FM
Online Johnny10
« Reply #41 on: October 01, 2016, 12:20:47 am »
I have to say mine is a bit funky smelling also.
Since this is first year or thereabouts unit 1348A
I thought it might have the same display chips as the 5216A but no. And I forgot 5216A is from late 50's
Different IC chips.
When I open it up will do some photos.
And make a new post.
Unless it miraculously recovers and then what would I post.  :-//
Offline bitseeker
« Reply #42 on: October 04, 2016, 12:21:17 am »
If it recovers, then give it a general teardown thread. Those are still good and folks will talk about theirs or ones they've used, etc.
I TEA.
Offline Cubdriver
  • Nixie addict
« Reply #43 on: October 04, 2016, 12:30:17 am »
I have two with the same issue (a failed custom part) that I've hopefully gotten working a replacement for.  I'll take photos when I dig into the repair.  It's been on the back burner for a while now...
-Pat
Offline anachrocomputer
« Reply #44 on: October 09, 2016, 10:31:35 pm »
Reading this thread prompted me to dig up my HP 5216A which I bought for £10 at Hanney's electronics shop in Bath in about 1996. It worked then, but has since suffered a failure whereby one Nixie digit is stuck at '8'. Also, it no longer lights the 'gate' lamp and hence will not measure frequency (it seems OK measuring period).
Photo here: https://www.flickr.com/photos/anachrocomputer/30125695561
Has anyone found a source of better-scanned schematics for the 5216A?
Offline Cubdriver
  • Nixie addict
« Reply #45 on: October 09, 2016, 11:55:57 pm »
I always try to get paper copies of the manuals when possible, but if I'm in a hurry or no paper copy is easily available, for good PDF scans Artek Manuals is hard to beat. They list a scan of the 5216A for US$12.50, and it is typically downloadable fairly quickly once purchased (I'm not certain, but I believe that they manually approve the purchases, thus the delay).  A link to the download is e-mailed once things go through.
-Pat
« Last Edit: October 09, 2016, 11:58:30 pm by Cubdriver »
Offline bitseeker
« Reply #46 on: October 11, 2016, 02:01:48 am »
That's a nice one as well, John. It's as if they're just coming out of the woodwork now. ;D
I TEA.
Online Johnny10
« Reply #47 on: November 05, 2016, 11:50:45 am »
Update:
Received the new HP 1820-0119 IC today and couldn't wait to solder the new chip into the 5216A.
I ended up buying 2 chips on eBay for 17 dollars. Yikes!
They were HP stamped but not gold plated as are the rest of the chips.
Now all tubes are working properly and also all Frequency and Sensitivity knob positions.
Measuring 10Mhz from the back of my new ovenized 5335A shows 10.00002 / 10.00003 pretty good!
« Last Edit: November 05, 2016, 01:15:03 pm by Johnny10 »
The following users thanked this post: zike
Online Johnny10
« Reply #48 on: November 05, 2016, 05:18:10 pm »
Anachrocomputer
I followed the 9 and 8 pin on the  1820-0119 chips. These pins connect each chip in series.
When I reached the 6th chip there was wrong voltage.
Checked the BCD code and chip 6 was outputting the code for "8".
Did not change no matter the input.
Following the pinouts through to the last driver chip all 1820-0092 they all had proper high and low signals.
Only the one chip showed a problem.
Of course took a few hours to decipher all the reverse signal levels through to each nixie tube.
I would check that Decade counter chip for the nixie tube showing "8".
Pin 9 feeds pin 8 of the following chip. This is where the error showed up on mine.
I then eliminated the Buffer Storage chip and the Decoder driver.
By following the BCD Code between chips using the A4 Main Board Schematic page 3 of 3.
The manual also has individual pin layouts and notes on each of the chips in the driver circuit.
Good Luck,
Offline bitseeker
« Reply #49 on: November 06, 2016, 02:56:23 am »
Yeah, they are rather pricey. Congrats on the successful repair. She lives! :clap:
I TEA.
Offline zike
« Reply #50 on: December 28, 2017, 10:10:37 pm »
So it appears "attached" by relevance... (despite thread being dormant over a year...)
I just fixed a 5216A with a peculiar, but ultimately similar, problem. At first I thought it was  grossly out of cal, but the error was huge and changed depending on the sampling time/decade; whereas the well-aged internal crystal was dead nuts (<0.1 ppm error!).
Turned out the 5th digit appeared superficially to increment (even carried  tens to the 6th digit),  *except* it skipped 2, 3, 6 and 7.  Somehow that digit's 1820-0093 decade counter (predecessor of the faulty 1820-0119 above) had a stuck bit, but still worked otherwise; it just divided by 6, instead of 10!
I surmised the 1820-0093 and -0119 IC pinouts were identical, based on schematic backdates. Indeed, a -0119, pulled from a later-model counter with other issues, works fine in place of the failed -0093. Which is lucky as the -0093 appears even more $$$ "unobtainium".
Also worth noting, these parts (and the unusual upside-down Burroughs B-5560 Nixies) are shared with the lesser 5221A and 5321A 'economy' counter models, which are more common, and less worth fixing.
Hope this info helps someone else down the line.
Offline bitseeker
« Reply #51 on: January 03, 2018, 12:28:51 am »
Thanks for the substitution info, Zike.
I TEA.
