Hi all, I just received a brand new Hantek AWG - the HDG2022B. The thing would not turn on out of the box but did eventually after a few power cycles. Unfortunately that issue continued, with the unit flat out stopping to work (or starting to) out of the blue when plugged in and turned on. It seems that something is wrong with the switching power supply. This thing seems to have two separate sections, one for 5V (not used) and 12V (powering only a fan) and the other one powering the main board with +-17.5V and +5V. The smaller section always works but the bigger one does not. Occasionally I hear 1 per second "clicking" sound on the bigger transformer, looking like the supply is trying to boot but failing. Voltage at that time also fluctuates from 0 to about 2-3V every second. This clicking continues for some seconds after turn off, as well. Sometimes though it just doesn't do anything at all and sits dead.
Any idea where to start looking for faults? I am not an expert on switching supplies and I'm rather scared of high voltages to randomly probe around , like any typical non-power electrical engineer. I have tried refreshing most of the joints, not easy due to non-Pb solder, but that didn't help. Poking around at all components with the fluke voltalert does not help either.
