I have an old HP54503A that has lost it memory
. The NVRAM died. Realtime bandwidth is useless on this old machine with 20M/s, but it's a real nice machine to work with, up to say a MHz, so i like to keep it in working order. The old DS1235YW-120, 28 pin sram can be replaced with a DS1230-120 that's still in production and i sampled one.
Question, how to desolder the old ds1235. It's on a 3 or 4 layer board. I first resoldered all the pins. Then i used a pen style solder sucker to remove the bulk of the solder. And used solder wick after that. But it's stuck as a brick.
How do you remove such a bastard with 28 pins, you can't cut the pins individually and pull em out because you can't reach them because the package is wider as standard dip. And i don,t want to ruin all those nice gold plated .5 mm traces.
