Wow ! Thanks a lot everyone !
@oldway Thank you, I did heard about that a while ago, didn't remember... There is one 60km from me in La Seyne sur Mer, worth give a try !
@singapol Thank you very much for the documentation, I will apply the driving principle, good to know the basics. About the dynamic load, It might be a good small project to test it when it'll be built.
thank you again for the applied example of how to use the LM723, very clear and simple, I saw another example
here about how to use it (french article on elektor december 1982) but it wasn't that simple for a beginner !
This one is nice too but doesn't fit the transformer.
@cheeseit Oh ! Thank you ! I've never heard of TL783 before, and the datasheet seems very similar to the LM317 on how to use it ! I'm thinking about that design that would fit the transformer (it can give around 110V DC in full wave bridge rectifier mode to feed the power transistor)
After that, I would need to look at adding current limiting to the circuit.
Or if I use the LM723, can I modify this design like this :
Of course, resistors values has to be changed as well as the driving transistor. I have a BUT12AF that would be good as power transistor I guess.
What do you think ?
(Sorry for the crude windows paint editing)
