Author Topic: HP6236B Triple Output Power Supply Current Gauge not working  (Read 1602 times)
Offline parasabuy22Topic starter
« on: March 30, 2017, 03:07:49 am »
Hi folks... I have an HP 6236B Triple Output Power Supply.  The volt meter seems to be working fine, but the current meter is not responding to any input.  The meter looks like it took a hit during shipment and broke.  I'm open to replacing the Ammeter but I can't seem to find one anywhere for a reasonable price.
Any suggestions?  I would appreciate leads to suppliers or advice on how to go about faxing this ammeter.
Thank you.
Paras.
Offline JXL
Re: HP6236B Triple Output Power Supply Current Gauge not working
« Reply #1 on: March 30, 2017, 04:58:06 am »
Search youtube for "HP6237B Meter Replacement".  The HP6237B is almost the same as your HP6236B.
« Reply #2 on: May 06, 2017, 08:03:11 pm »
OK, thanks... saw the video.  Are there any others that are similar?  It seems the gauges are supposed to be the same across many models but with the faceplates changed.  I also don't seem to find much on eBay, so perhaps I'm not searching with the right terms?  Or if there is someplace else I should search that you know, I would appreciate the direction.  Thanks a lot. Paras.
