Author Topic: HP8485A power sensor reads erratically  (Read 224 times)
Offline alan.bainTopic starter
« on: December 22, 2024, 02:28:30 pm »
I've got a working HP 8485A power sensor and another one which I suspect is dead, but am curious as to the failure mode. Most of the dead one I have seen won't zero. This one zeros fine and can be calibrated but the reading is unstable. It's easiest to see on an analogue meter like the 435 the needle wobbles significantly (rendering it unusable of course).
Is this a known failure mode?  I'm aware they are basically unrepairable!
Alan
Offline Stray Electron
Re: HP8485A power sensor reads erratically
« Reply #1 on: December 22, 2024, 08:35:26 pm »
  Are you sure that the problem isn't in the cable assembly?   The cable for my HP Power Meter is gimpy and sometimes works and sometimes doesn't.  And it acts the same with all of the sensors that I own.
  I don't use the meter much so I've never tried to located the bad spot in the cable or to fix it.
« Reply #2 on: December 23, 2024, 12:00:34 am »
Good thought. I have two other cables so will try them.
Alan
