« Reply #8 on: December 18, 2021, 09:11:17 pm »
I might try some nixie tube socket pins soldered onto a PCB (using modelling clay + trial and error + vernier caliper to get the pin spacing correct) with tracks leading to pins on the outside edge of the board. I can insert this in-between the CRT tube and the plug and use my HV probe to measure the voltages on each of the 14 pins. At least it's something to try out. There are no accessible test points that I can see or that are safe to reach. Or maybe I am making things more difficult for myself and there is an obvious and simple way that I'm missing.
PS I have some piercing probes but I don't want to damage any cable insulation as this will encourage possible voltage arching.
« Last Edit: December 18, 2021, 09:18:26 pm by djsb »
Logged
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
