Hi, tysm for posting this. Hoping maybe you can help resolve a question about the monoblock version.
Both versions are based on the Carver PM 2.0, afaict. The original manual for the Carver PM-2.0t (not sure what the "t" represents) gives the output specs as follows:
465wpc @ 8 ohms; both channels driven
600wpc @ 4 ohms; both channels driven
450wpc @ 2 ohms; both channels driven
1000w @ 4 ohms; mono output
That 2 ohm rating seems odd, but most folks familiar w Carver's mag field amps will never run them into a low-impedance load, so nbd.
But here's the question. 1200w total in stereo into 4 ohms, and 1000w total in mono into 4 ohms makes sense. And Carver's factory monoblock amp has a single set of 2 output binding posts, with a choice of using either of the single TRS or XLR inputs. Fine, no problem.
However, on the Clair Bros monoblock amps, it appears that they've modded the standard 2-channel amps as there are two sets of binding posts, and what appears to be spaces where one of the two TRS & XLR inputs have been removed. So only one input channel, but what appears to be two output channels.
Clair rates their modified monoblock amps at 1000w. I would assume that means 1000w TOTAL at 4 ohms into a single output channel, and that only one of the two sets of output binding posts are active. But since the amps have been modded, and I have no idea exactly to what extent, I'm trying to verify the output capability of this amp. And I'm puzzled that they went to the trouble of removing one set of inputs, but left two sets of outputs. Surely this amp is not putting out two identical channels of 1000w @ 4 ohms, is it?
It's also puzzling to me that Clair didn't start with Carver's Monoblock version to begin with, since it has the obvious single I/O channel. I'm going to post pix of the Clair vs Carver Monoblock front & rear panels if the site lets me.
Any chance that you can you shed any light on all this, having had them apart?
I'm considering buying some of these for use with a set of very power-hungry 21" sub cabs that are rated for 800w @ 4 ohms. And I'd really like to make sure there's plenty of headroom. If that "monoblock" is only delivering ~600w to each of the two outputs, it will definitely not serve my purposes. If it's delivering 1000w to a single output channel only, it could work well. If it's delivering 1000w to TWO output channels, well... that would be fantastic. But that strikes me as highly unlikely.
