How can I estimate how much current each voltage rail(+15v,-15v,+5v,-5v,+28v,-12.6v) SHOULD supply? So far the +15v rail goes to 4A with a stable 15v, but the -15v only goes to 3.2 amps and then voltage starts to drop. I have attached the main A6 supply schematic and the A6A2 regulator schematic. Can anyone help me estimate the current capacity? Thanks.
PS I'm going to test the values of the 0.07 Ohm sense resistors anyway.
Update:They check out OK. New 0.07R 3W 1% resistors fitted just in case.
Also tested continuity between the plug in A6A2 regulator PCB and the 72 pin SIMM socket it plugs into. All pins OK.
