Author Topic: Tektronix TDS-540 Console Port?  (Read 4293 times)
Offline EB5AGVTopic starter
  • The best recycling is repairing
    • Amateur Radio and Test Equipment
« on: July 21, 2016, 09:45:30 pm »
Hi all,
I am working on a Tektronix TDS540 which, as most units, has some ACQ board problems. I have already carefully cleaned residue and replaced caps and have also removed some faulty opamps and TTL circuits, which will be soon replaced by new ones.
But I don't know how to get into the serial console port for detailed troubleshooting. I have read about building an adapter. Could someone let me know how to do that?. My unit does not have Option 13. Should I have it?
Best regards,
Jose
JOSE V. GAVILA - La Canyada - Valencia (SPAIN)
http://agvradio.com  AGVradio
http://jvgavila.com   Personal WEB
Offline picburner
Re: Tektronix TDS-540 Console Port?
« Reply #1 on: July 22, 2016, 05:51:03 am »
this is the TDS console port schematic that I made several years ago:
The following users thanked this post: EB5AGV, evb149
« Reply #2 on: July 22, 2016, 08:01:58 am »
Thanks!. I will build one myself  :-/O
It will be a very useful tool to troubleshoot this unit, I am sure.
Regards,
Jose
Offline piotekp90
« Reply #3 on: October 02, 2018, 09:37:09 am »
Which port is a console port J37 or J40? I have read many topics about console port but I still don't know to which connector I should connect the converter. I see that orginal RS232 connection board is connected to J37.
Offline picburner
« Reply #4 on: October 02, 2018, 10:29:56 am »
J40 is the console port, J37 is reserved for opt 13 serial/parallel port.
Offline piotekp90
« Reply #5 on: October 04, 2018, 08:47:27 am »
I have redrawed your schematic and now I'm working on a PCB layout. Do I understand the J40 pinout correctly?
« Last Edit: October 05, 2018, 08:04:56 am by piotekp90 »
The following users thanked this post: worsthorse
Offline coromonadalix
« Reply #6 on: October 04, 2018, 10:22:22 am »
To be sure, while unpowered
Check the grounds and data pins going to the mcu with an ohm meter if they are at the right pins would be a start ...
Offline picburner
« Reply #7 on: October 04, 2018, 04:43:48 pm »
J37?? I guess you meant J40.
However the pins are marked right.
Keep in mind that in my schematic U1 (MC68681FN) is in PLCC-44 not DIP40.
Offline piotekp90
« Reply #8 on: October 05, 2018, 08:06:30 am »
I meant J40 (sorry my mistake). I have prepared schematic for PLCC44 version like in your schematic.
