I have an HP 8753E that I’m trying to fix.
I noted that I was getting a very poor response from port B prior to calibration. Upon disassembly I determined that there had been ESD damage to the coupler and the ~265 ohm film resistor inside was fried. I replaced this with a 270 ohm resistor using instruction I found online. After the replacement, the performance improved somewhat but it is still problematic.
I tried swapping the port couplers and the samplers, but regardless of the changes the problem stays on port B. My next suspicion is the solid state switch (A24 - HP 5086-7539).
Is there any way to easily test this? Is it possible and/or likely that ESD damage coming into port B would also knock out the switch behind it (which evidently is static sensitive)? Is there any way to repair the guts of this switch or is this a lost cause? Thanks for any insight you can provide.
Images:
Port B before fixing resistor
Port B after fixing resistor
Port B with a different (probably good) port coupler
Port A (working fine for reference).
