Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Com Express Motherboard - No Image
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Com Express Motherboard - No Image (Read 2407 times)
2X
Frequent Contributor
Country:
on:
March 14, 2024, 10:17:59 pm »
Hello, I have a (SOM-5898) Com Express Motherboard. The machine starts and also the CPU fan spins, but I have no image. I have one more identical PCB board with the same PCB part number, so I made a replacement on the bios chip. I took the bios chip from the working PCB and I replaced the chip_1 on the board that has no image and the same thing again.
https://www.advantech.com/en/products/9b97accf-0a5b-4166-bf75-38159d579dec/som-5898/mod_d5e189d0-b1a0-43b1-aa7d-256828660dcf
Last Edit: April 19, 2024, 10:58:27 pm by 2X
Logged
2X
Country:
Re: Com Express Motherboard - No Image
Reply #1 on:
April 19, 2024, 11:01:34 pm »
Finally I found the problem... the CPU didn't have supply. There was a Cold Solder Joint on the phase chip which drives the mosfets at CPU. I resolder the chip and now works fine.
Last Edit: April 20, 2024, 12:49:52 pm by 2X
Logged
alm
Super Contributor
Country:
Reply #2 on:
April 20, 2024, 10:09:04 am »
Thanks for updating us with the solution! This could be helpful if another person runs into the same problem.
Logged
Linux-GPIB packages for current Ubuntu versions
2X
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
