Hi all,
Wanted to share my journey fixing two of HP/Symmetricom 58503A.
I have two of those units that are broken. Both of them have bad oscillators which are in my case hp 10811-60212 but another member had 10811-60159 so I guess they are interchangeable.
When I power the units up they voltage regulators powering the heaters are getting really hot and the units draws... 1.5A.
When the heaters are disconnected the current goes down to about .5A
First of the units fails the self test, fails also a oxco and efc.. That's what I see in SatStat before it fills with errors so it disables updates.
When I look at the log I see "invalid header" messages.
reply: -113,"Undefined header"
reply: -102,"Syntax error"
Sent: *IDN?
------------------------------- Receiver Status -------------------------------
SYNCHRONIZATION ........................................... [ Outputs Invalid ]
SmartClock Mode ___________________________ Reference Outputs _______________
Locked TFOM 9 FFOM 3
Recovery 1PPS TI --
Holdover HOLD THR 1.000 us
>> Power-up: OCXO warm-up Holdover Uncertainty ____________
Predict --
ACQUISITION .............................................. [ GPS 1PPS Invalid ]
Tracking: 0 ____ Not Tracking: 8 ________ Time ____________________________
PRN El Az LOCL GPS 06:02:23 [?] 01 Jan 1998
* 1 -- --- GPS 1PPS Invalid: not tracking
* 6 -- --- ANT DLY 0 ns
* 9 -- --- Position ________________________
*20 -- --- MODE Survey: 0% complete
*22 -- --- Suspended: track <4 sats
*24 -- --- INIT LAT N xx:03:04.414
*25 -- --- INIT LON W xx:53:37.933
*28 -- --- INIT HGT +194.28 m (MSL)
ELEV MASK 10 deg *attempting to track
HEALTH MONITOR ...................................................... [ ERROR ]
Self Test: Err Int Pwr: OK Oven Pwr: OK OCXO: Err EFC: Err GPS Rcv: OK
The second unit fails self test, oxco and gps receiver. The serial link is also going up and down, and often I'm getting.. no response from the unit.
Sent: *IDN?
reply: HEWLETT-PACKARD,Z3805A,3542A0xxxx,3543B-A
Locked to TFOM 9 FFOM 3
Recovery 1PPS TI --
Predict --
ACQUISITION .......................................... [ GPS 1PPS CLK Invalid ]
Satellite Status __________________________ Time ____________________________
Tracking: 0 Not Tracking: 0 LOCL GPS 19:00:00 [?] -- --- ----
1PPS CLK Invalid: not tracking
ANT DLY 0 ns
Suspended: no track data
INIT LAT 0:00:00.000
INIT LON 0:00:00.000
ELEV MASK 0 deg INIT HGT +0.00 m (MSL)
Self Test: Err | Int Pwr: OK Oven Pwr: OK OCXO: Err EFC: OK GPS Rcv: Err
Wanted to ask if anybody has any experience fixing the oscillators and I guess heaters on them. When I connect the oscillators themselves... without the heaters they seem to be working.
Maybe somebody has those hp10811-60159 OXCOs so I can just get one of them for testing.
Second, wanted to know what kind of gps receiver I should get to replace the faulty one or is there a way to fix it?
Third, what would be a problem with communication over serial... should I see and how to see what are the serial settings on those devices.
What would be a problem with sending commands. It does look like a firmware may be corrupted.
Anybody having copy of the firmware I may use?
There is command in SatStat to upgrade firmware but I have programmer and adapter, can burn them if needed.
