Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Humidifier-Stopped working, no mist! how to test Piezo?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Humidifier-Stopped working, no mist! how to test Piezo? (Read 700 times)
Aakash
Contributor
Country:
on:
December 01, 2021, 05:12:01 pm »
My humidifier stopped working, there is no mist coming out of it. I can hear the fan is running.
Can anybody let me know how can I check if the piezo is working or if I should replace the piezo.
Any suggestions please help.
Logged
Haenk
Frequent Contributor
Country:
Re: Humidifier-Stopped working, no mist! how to test Piezo?
Reply #1 on:
December 03, 2021, 11:17:04 am »
Not sure if this works, but maybe use a laserpointer and the piezo element as a "mirror" and project the laser dot. If the projected dot gets broader, when the cleaner is switched on, the piezo is working.
Logged
wraper
Supporter
Country:
Reply #2 on:
December 03, 2021, 11:27:28 am »
Replacing transducer most likely won't help since the problem most likely is in electronics which are driving it. Unless it's electrically shorted or has visually observable damage, not likely there is anything wrong with it.
Logged
Xenon
Contributor
Country:
Reply #3 on:
December 03, 2021, 04:31:00 pm »
Those piezo thingies are also used in medical humidifiers. They fail when they run dry because of overheating (they are driven hard).
Often the failure is visible on the piezo surface. It has a discoloration in the center or the surface peels off (tiny blisters).
Do you see anything similar?
Logged
Aakash
Contributor
Country:
Reply #4 on:
December 03, 2021, 06:06:30 pm »
There is no discoloration that I see of, is there any way to drive it externally with a function generator and get to know if it's working fine?
Logged
james_s
Super Contributor
Country:
Reply #5 on:
December 03, 2021, 06:17:04 pm »
You could connect it to an audio amplifier, piezo elements are very commonly used as inexpensive tweeters.
Logged
Aakash
Aakash
Contributor
Country:
Reply #6 on:
December 03, 2021, 08:23:59 pm »
I don't have any idea to build an audio amplifier, do you have any base circuit that I can build?
Logged
james_s
Super Contributor
Country:
Reply #7 on:
December 03, 2021, 08:56:29 pm »
Build? If you take 10 seconds to search with google you will find numerous circuits, but surely you already have some kind of audio device around? Or just buy a small amplifier module, you can get them for a few dollars or less.
Logged
Aakash
Renate
Super Contributor
Country:
Reply #8 on:
December 04, 2021, 01:36:42 pm »
I say that if it looks good, connect it to your scope and tap it lightly. You should see plenty of volts.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Library
