I bought a used boat that came with a Humminbird 859ci HD, but issue is some thief cut the transducer cables and made off with the ends.
I believe it is this sonar but I do not have a black wire as shown in this diagram:
http://forums.sideimagingsoft.com/index.php?action=dlattach;topic=5388.0;attach=8094;image(I have found pins 2 and 4 are used for side imaging transducers that I do not have)
I was going to connect the wires and see if it recognizes the transducer, but...
I also have a temp/speed wheel sensor. I believe this is connected via a Y cable so both run to the main transducer port, and only the speed wheel signal is used, but I have not found out this wiring. Does someone have a Y cable that they could ohm out how the pins are combined? The T/S wheel had a 4-pin square connector and black, brown, yellow, and red wires. I may be able to at least deduce which pin the speed signal goes to and ultimately ID which wire if I knew how the Y cable is wired.
Note that the manual says the 900 series (only) uses a square port for the T/S wheel and the 800 series has the same square port with 5 pins. I have not found a pinout for that or what it's used for on the 800 series. It may just be reused hardware for multiple series to save costs.
