Author Topic: Huntron Tracker 2000 Unit A2 U2 MPU Dump?  (Read 3114 times)
Offline Chris56000Topic starter
« on: March 27, 2017, 01:29:32 pm »
Hi!
The price of these Huntron Tracker 2000 instruments is sky-rocketing thro' the roof on fleabay, and it looks like I might have to make one in instalments from the Service manual if I'm ever to own one of my own which I'd like!!!
Has anyone been able to make a copy of the hex. dump from the 87C750 U2 (Huntron P/N 06-5102) or knows if I can get this device as a spare part anywhere?
Chris Williams
« Last Edit: March 27, 2017, 02:17:57 pm by Chris56000 »
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline denimdragon
  • "Hole charge chaser and wanna-be o-scope fixer"
Re: Huntron Tracker 2000 Unit A2 U2 MPU Dump?
« Reply #1 on: May 19, 2017, 08:02:53 pm »
Did you ever find anything @Chris56000 ?
"Hi there. I'm short in the hair department, do you mind if I pull a few strands from your head? Thanks!"
Offline kripton2035
« Reply #2 on: May 19, 2017, 08:23:46 pm »
I'm pretty sure it would be easier to reprogram the whole thing with an arduino and a small tft display ...
that huntron device is from the last century ...
Offline oldway
« Reply #3 on: May 20, 2017, 05:29:28 am »
Most of Hameg analog oscilloscopes have a usefull component tester.
It is the same principle of working than the Huntron Tracker 2000.
My workhorse is an Hameg HM605 and I am mostly repairing power electronics and vintage audio gears.
Offline kripton2035
« Reply #4 on: May 20, 2017, 05:46:36 am »
the huntron has some nice features that are not in the component tester of scopes.
- you can compare two traces on the same display at the same time
- you can adjust the test signal level and frequency (you can test at 200mV to eliminate semiconductors switching)
- on some models you can test up to 64 pins of a circuit at the same time
- you can export the signatures on a connected computer for later examination.
I have an old hameg scope with the component tester, and I want to switch to something better
but I always found the prices of the polar and huntron devices way to expensive for what's is inside.
this should not cost more than $100 to build. why are they selling it $1000 or more ?
Offline oldway
« Reply #5 on: May 20, 2017, 12:15:26 pm »
§100 ? are you kidding ?  :-DD
Perhaps you think that workforce is free in the US and that Huntron was using second hand components.   |O
Offline kripton2035
« Reply #6 on: May 20, 2017, 12:42:17 pm »
I don't mean to make and sell it, but to build it myself for my own use.
I don't want to use a crt display
most of the price of the huntron must reside in the patents they have for this kind of devices that prevent anyone to sell identical devices.
Offline oldway
« Reply #7 on: May 21, 2017, 05:07:38 am »
Huntron has pushed the principle of the octopus x/y curve tracer very far, but the Hameg component tester is already very useful.
For troubleshooting, I find it essential.
It is not really necessary to have the display of 2 curves, nor to have different frequencies and output levels.
crt display is still a winner for such application as dso is not good for x/y display.
Even the Hameg octopus adapter HZ65 has became hard to find and expensive....
« Last Edit: May 21, 2017, 05:19:26 am by oldway »
