Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
HV diode test
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: HV diode test (Read 2055 times)
jfphp
Regular Contributor
HV diode test
on:
March 11, 2016, 02:50:04 pm »
Hello,
How can I test HV diode (service of several KV) ? There are alone, not mounted with capacitors. Standart diode test gives no result. If I apply HV to mesure the current I have to float the multimeter beyond the specs... Any idea ? Thank you.
Logged
bktemp
Super Contributor
Country:
Re: HV diode test
Reply #1 on:
March 11, 2016, 03:04:09 pm »
Apply a high enough voltage to make it conduct and check if the forward voltage drop is in the expected range. Most high voltage diodes have a forward voltage in the range 5-100V.
If it works, apply a high reverse voltage and measure the leakage current. Maybe you should add some protection across the current shunt in case the diode fails at a high voltage.
Logged
Seekonk
Super Contributor
Country:
Re: HV diode test
Reply #2 on:
March 11, 2016, 03:48:42 pm »
I tested a microwave oven diode last week and that had stacked a forward voltage of 7.5V. For sure a HV diode will be at least 50V.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
HV diode test
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
