Those particular caps are used in the charge pump. Tek printed the meter scale to fit a brand-new instrument whose caps had dielectric absorption normal for that type. At the time the 130 was designed, that was probably paper/oil Sprague "Telecap" Black Beauty, commonly referred to as Bumblebee today. When new, those paper caps had more DA than polyester, and they've increased over time in both value and DA. With my own 130 (which came with Sprague 160P "DiFilm" paper/plastic with "HCX" impregnant) I noticed a high reading at mid-scale when top and bottom were trimmed. When I replaced them with polypropylene, I got a low mid-scale reading. I believe plastic is too good. I ended up faking some DA by paralleling each cap with a series RC. I got good results when I set the added time constant to match the mid-scale pulse frequency, while setting R to give the right amount of correction. I did this exercise with an RC substitution box then tacked in the results. It might be gilding the lily but I had fun.
