Author Topic: I just got one Solartron 7075 When starting up, the output line 1400 will flash  (Read 2944 times)
Offline MuShanTopic starter
  • Country: cn
Received a Solarton 7075. After repairing its power supply, it will output a line of 1400 when turned on. I switched the integration time, which can increase its number of digits. It shows that the self-test did not show a 7.0V reference voltage
I don't have a good idea for checking anymore. I have some doubts about which reed pipes have problems
When pressing AC measurement, only the background light of V lights up, and the light of AC signal does not light up
  • Country: cn
I hope everyone can give me some ideas for inspection
Offline coromonadalix
  • Country: cn
我已经找到了它的原理图并且看过 干簧管好像是正常的
今天我敲击PCB时出现了正常的显示
I have found its schematic and have looked at the clarinet, which seems to be normal
Today, when I was tapping the PCB, there was a normal display
Online tggzzz
今天我敲击PCB时出现了正常的显示
Clean all the inter-board connectors, and reseat them carefully. They aren't the most reliable.
Online factory
Mine had that problem too, it was working fine before I received it, but when it arrived it would only display even numbers and no one been inside since its last cal by Schlumberger, the board interconnection was causing it.
  • Country: cn
When I just had a conversation with a friend, he told me that some very old multimeter PCBs and components may have water absorption, which may cause abnormalities It's interesting that I used a hot air gun to blow the positions of the two large relays on the board, which can now measure the DC voltage. I tested 100mV 1V 10V and 30V
  • Country: cn
I have dismantled it for observation, and the coating is very perfect. I have found a rough direction so far
  • Country: cn
It's very interesting. I used a hot air gun for heating, and now I can see that there is a reading of 10V
Online tggzzz
The Solartron 7081 manual recommends that - after a long period in storage - it is wrapped in a thermal insulation and left powered for 24 hours. I used a blanket, and the stability did improve.
  • Country: cn
Now the area I am in is already at night. Tomorrow, I will dismantle it for heating and take a look
  • Country: cn
Today I took it down and heated it up, but found that the effect was not good and it returned to its earliest state
