Author Topic: I killed my usb powered router by accidentally feeding it 12v..I want to save it  (Read 3122 times)
Offline bobbydazzlerTopic starter
As the topic states I've killed my router via over voltage.  When I apply usb power now there seems to be a short in the dc-dc converter right after the micro usb jack and it gets really hot really fast.  I'm hoping I can desolder/disconnect the dc-dc power supply and feed 3.3v in via the serial port header and it might still work(I assume the dc-dc converter was outputting 3.3v because apparently the router runs fine with usb power down to 3v).  Here's a photo of my router board, the dc-dc converter is in between the micro usb and usb port, I'm thinking I need to desolder the 5pin ic which I guess is controller the inductor?  Anyone have any thoughts/ideas on what I need to do?
Online daisizhou
  • Country: cn
It is recommended that you try replacing the 5-pin chip.After attempting to unload the 5-pin chip, measure the circuit again for a short circuit fault
daisizhou#sina.com #=@
Online magic
Identify the buck converter. The board may be running on less than 3.3V and you could fry it (if it isn't fried already) by applying 3.3V.
Offline DavidAlfa
Take a proper image of the DC converter.
You might have been extremely lucky and the short be caused by a capacitor or diode, but I don't think so!
Well I've desoldered the 5pin IC and it fixed the short and after supplying 3.3v to the serial port vcc/gnd pins the router works fine, I can connect fine to my 5ghz wifi access point lol even the full sized USB port still works if I also add the micro usb input power.  Thanks everyone now  need to bodge up a permanent 3.3v power supply.  I wasn't able to identify the IC to make sure the output voltage was 3.3v but I think it's fine now anyway.
Online magic
Post a picture, maybe somebody will recognize this chip.
I once fixed a device with a small switcher like that simply by replacing it with LM317, couldn't be assed to identify and repair it properly :-DD
I couldn't read the writing on it before I desoldered it and now it's definitely unreadable after I dumped a giant solder blob on it to remove it, if I do apply I small internal 3.3v power supply to run off usb power I will probably use some AMS 1117's.  The router's pulling 0.350ma on average so I think a AMS 1117 can handle that.
Offline DavidAlfa
Just clean it thoroughly, some brushing with any solvent will work, marking is usually laser-engraved and won't go away.
The following users thanked this post: wraper
Offline Miti
The USB host must need 5V.
Fear does not stop death, it stops life.
Offline shapirus
  • Country: ua
Its power pins are probably wired directly to the input jack's one.
Offline jonpaul
    • IEEE Spectrum
get a new one $3
The Internet Dinosaur..
passionate about analog electronics since 1950s
I can't get a non blurry picture from my camera, I've looked with my magnifying glass and all I can read is FV9VG.. there might be something written after that I can't make out.
Offline fzabkar
The marking style looks like Silergy's, in which case the marking would be FVxyz (FV = part ID, x = year, y = week, z = lot number). Unfortunately, Silergy's datasheets are not publicly available.
I think the best you can do is to trace the circuit and try to find a substitute.
