I am rounding up backup parts for a new BK Precision 1655A AC Power Supply that I am buying. I have learned to buy spare parts as soon as I buy equipment that has a long life, because it is likely that the unit will not be manufactured forever and parts may not be available, in the future.
There are two consumable parts that are listed in the manual, with an explanation of how to change them, but they are not listed in the parts BOM. One is the fuse in the leakage probe. It has no stamp on the end cap, but I was finally able to get the manufacturer to find out that it is a 500mA/1KV ceramic safety fuse. The lack of the stamp is common to all of these fuses and a known problem, to the owner community.
The other item is the brush for the coil. The manufacture tells me that you must buy a whole new coil assembly, even though the manual explains how to replace the individual brush. So, I am hopeful that you can tell me a work-around, as I know very little about such brushes. Might I buy a larger brush and file it down to size?
Here is a good YT video made by an owner. It shows the brush at 8:40.
I have done an exhaustive search on the web. I am very much looking forward to your replies. Thank you for your help.
