yup my adaptor is fine,just the charger wont power up
Just wanted to follow up on this, with some pictures.
You need to check the voltages around U2 and Q27 - you can see my measurements in the pictures. The 5v regulator in this charger is more or less directly copied from the TL431 datasheet (apart from the resistor values).
I had to change both the TL431 (U2) and the NPN transistor (Q27) in mine.
Now beware - the chinese "431" marked part is actually not pin compatible with the TL431 from Texas Instruments, that I had. The pinout actually matches TL432 instead, so I had to flip my TL431 around, and connect a wire from anode to ground, as you can see in the picture.
From the datasheet:
"The TL432 device has exactly the same functionality and electrical specifications as the TL431 device, but has different pinouts for the DBV, DBZ, and PK packages."If I had to purchase a replacement, I would get the TL432 instead, but I already had the TL431 so I couldn't be bothered.
As for the NPN transistor (Q27), I believe any generic NPN transistor will work, as long as it can handle the current draw of the Liitokala (only the logic/display/etc., not the charging) - I just used whatever high current NPN transistor I could find. In my case I used a ZXTN19100CFF - maybe overkill, but it works.
