Author Topic: I need some help troubleshooting a low frequency oscillation in a tubeamp SOLVED  (Read 12263 times)
Offline PlanobillyTopic starter
Hi guys,
I just finished the build of a AB763 Fender style Deluxe Reverb amp. Everything works well and the amp sounds good to my taste.
The issue is that I have a low frequency oscillation which can be heard at idle. I think this sound would be considered "motorboating" It appears with all gain controls set at zero. I seems to be associated with channel one. When the channel one gain is increased to about 60% it goes away and when the gain is increased to about 65% it comes back.
THe amp is built very close to this schematic. http://el34world.com/Hoffman/images/Hoffman_AB763.pdf
All the voltages are normal and I have changed all the tubes. I have moved all the wires around to no effect. I tried installing a low wattage tube (5751) in V1 to no effect. I have re-flowed many solder connections. I have changed 95% of the capacitors in the amp to no effect on the oscillation. The cap changes did make the amp sound better....used orange drop caps.
Everything is built per the schematic except the cathode caps are 25uf and not 22uf. 25uf is what Fender put in their amps. There is a error on the schematic with the value of the resistors in the power supply which I changed to 10K to provide correct plate voltages.
I have pretty much done everything I know how to do to try to resolve the issue. At this point I really need some guidance on how to proceed.
Thanks,
Billy
« Last Edit: September 03, 2016, 01:08:18 am by Planobilly »
Offline uncle_bob
Hi
Do you have an oscilloscope or other test gear? Best bet is that it actually is a high frequency oscillation that impacts the bias. That gets it down to the point you can hear it. Probe through the circuit with a scope that has at least a 10 MHz bandwidth (100 would be better) and you likely will find the problem stage. Then it's a matter of fixing the bypassing and grounding to make it go away.
Bob
Hi Bob,
Yes I have a 100 MHz scope, a newer Owan digital. I also used a probe connected to another amp to hear the sound it was making. The sound does not appear on the plates of V1 and V2.
I am not very skilled at using my scope. When looking at the signal at the output transformer there is a voltage both positive and negative that appears with the sound.
Perhaps you could give me some guidance on how to set up the scope and just what to look for.
Thanks,
Billy
Here is a photo if that helps.
Billy
Offline uncle_bob
Hi
Start at the front end of the circuit (V1 and V2) and work your way to the output (V7). At some point, you will find a tube with junk on the plate. Once you know which tube that is, you can start trying to figure out what the cause is. Equally, you can start from V7 and work back towards the front end. There are a couple of branches in the circuit, so it's not entirely a linear process. An alternative is to make a list of all the plate sections (V1A, V1B, V2A, V2B ....) and check each and every one of them. Check off which ones have junk and which ones do not have junk.
As always - be careful to keep things grounded and avoid touching the signal leads (High Voltage ....).
Bob
Online Andy Watson
Please forgive the obvious question (but you never know) - have you tried removing or otherwise disabling V5?
Offline uncle_bob
Hi
To the point: Since this is basically an AC coupled circuit, you can "randomly" pull tubes. There is no worry about pulling one and frying another. That is an OK way to isolate which tube (or section) is creating the problem.
Bob
Thanks Bob,
LOL...I will use due care when probing the circuit!! I sure don't want any high voltage drama...lol
On the V5 plate there is a 3.5 Hz signal at 1.7 VRMS
V4 plate 312KHz 23mv
V3 plate 107 KHz 50mv
V2 plate 10 Hz at 5 mv...I assume that is what I am hearing
V1 plate 10 Hz at 11mv
V6 grid 10 Hz at 14mv
V7 output tube grid 107 Hz and 120 Hz at 3.1 V
Not sure just what all that indicates.
Billy
I just pulled V5 with little change except for how loud the signal is.
I will go pull each tube one at a time.
Billy
Offline uncle_bob
Thanks Bob,
Billy
Hi
Well if the main component on the output is 120 Hz, that's an easy one .... your power supply is getting into the output.  Unless you see the 10 Hz on V7, that's not what you are hearing.
The 312 KHz on V4 is the sort of thing that I suspected at first. The only way for that to happen is if the stage is oscillating. You either have a bum ground or a bad bypass. In this case the location of the ground and the size / type of the bypass could be what is wrong.
Bob
Re: I need some help troubleshooting a low frequency oscillation in a tube amp
« Reply #10 on: September 01, 2016, 05:54:54 pm »
Pulling the tube at V3 stopped the oscillation. V3 is the reverb driver.
Billy
Be back in five min
« Last Edit: September 01, 2016, 05:57:25 pm by Planobilly »
Offline uncle_bob
« Reply #11 on: September 01, 2016, 05:56:40 pm »
Billy
Hi
That would suggest that you poke around V3 and see what's going on. In addition to ground and bypass, lead dress (which wire goes where) can be an issue. Did the low frequency crap go away with V3 as well?
Bob
Offline woodchips
« Reply #12 on: September 01, 2016, 06:31:59 pm »
Wow, what a lot of valves!
My very rusty experience is that motorboating is very often caused by a naff or missing cathode bypass capacitor, might be worth a look at the 22uF one on V3.
Online Andy Watson
« Reply #13 on: September 01, 2016, 06:57:41 pm »
The point of pulling V5 is that it is a low-frequency oscillator. I was thinking that may be it wasn't being fully disabled by the foot switch. However, looks like events have overtaken me!
I agree with Ian. Check that there are no unintended DC paths to the gird of V3 and from the cathode - it looks very close to the metalwork of the chasis in the photo.
« Reply #14 on: September 01, 2016, 07:01:06 pm »
I am looking at the circuit now.
I am getting a plate voltage of 424V which seems perhaps a little high to me.The current must not be to much due to the 2.2k cathode resistor ground. Why would there be a need for such a high plate voltage??
The voltage at the power supply choke is 435V, and what I would consider normal. The data sheet primary impedance  on the reverb driver transformer is 22800 ohms and the inductance is 95 H and 8 ohm secondary
I moved the heater wire a bit and re-soldered. No change. I also removed V4 with  all the other tubes in with no effect, so this seems confined to V3. I also moved the reverb transformer around to no effect. I also replaced the V3 tube with a new one with no change. I also removed V2 and the sound is still there.
As I remember the 435V on the V3 plate was indicated on the original Fender schematic.....perhaps that is correct...
Billy
EDIT: No unintended path to ground on the cathode
« Last Edit: September 01, 2016, 07:15:09 pm by Planobilly »
Online Andy Watson
« Reply #15 on: September 01, 2016, 07:06:40 pm »
There is no plate resistance as such, just the DC resistance of the transformer - so I would expect to see almost the power supply voltage on the plate.
And what is the voltage on the cathode?
And (whilst you're there) what is the voltage on the grid?
« Last Edit: September 01, 2016, 07:14:22 pm by Andy Watson »
« Reply #16 on: September 01, 2016, 07:26:41 pm »
High Andy,
8.5V cathode
8mv on the grid
Billy
« Reply #17 on: September 01, 2016, 07:42:33 pm »
One other perhaps unrelated issue.
The small amount of hum that exist is reduced by touching the scope ground to the case. Checking the mains ground wire attachment point now.
Online Andy Watson
« Reply #18 on: September 01, 2016, 08:04:24 pm »
Voltages looks very reasonable.
The case is connected to the ground of the circuit?
Offline uncle_bob
« Reply #19 on: September 01, 2016, 08:35:43 pm »
Hi
For proper measurements:
1) The chassis of the amp needs to be grounded.
2) The chassis of the scope needs to be grounded.
3) The ground lead on the scope probe needs to be clipped to a ground lug on the chassis near the point you are looking at.
If things are floating relative to each other ... who knows what you might see.
Best gess right now:
The plate lead on V3 is to close to the grid lead.
Bob
« Reply #20 on: September 01, 2016, 09:09:56 pm »
Hi guys,
Under the mains plug there is a earth ground to the chassis. Three inches away there is a chassis ground where everything else is grounded to.
The scope is grounded to the mains through the power cord. I could not duplicate the reduction in hum again.
I will remove and resolder the plate lead and change the position of the plate lead to put it on top and have the grid lead closest to the cathode lead. Having three wires that cross in close proximity jumping across the tube I hope will solve the issue....I hope!!
Thanks,
Billy
« Reply #21 on: September 01, 2016, 10:27:09 pm »
Moved the wires well far enough apart. No change.... I also disconnect the grid lead from V3 with no change. I don't think I have any more 25uf caps but I could change out the cathode cap for some higher value that I have to verify the cathode cap.
I think I will take a break and come back to this in a hour or so.
Thanks for all the help so far.
Billy
Offline uncle_bob
« Reply #22 on: September 01, 2016, 11:11:30 pm »
Hi
Something like a 0.1uf ceramic from the cathode to ground may help.
Bob
« Reply #23 on: September 01, 2016, 11:51:12 pm »
Hi Bob,
Took a break and thought about this. Could I disconnect the plate voltage from V3 to see the effect?  Also I will place a 1 uf cap to ground. I assume you mean place a 1uf in series with the 25uf cathode cap.
Billy
EDIT: I disconnected the plate at the V3 tube and the sound is still there......So now there is no conduction through the tube...I assume the issue must be somewhere else...perplexing..lol
« Last Edit: September 02, 2016, 12:01:05 am by Planobilly »
Offline uncle_bob
« Reply #24 on: September 02, 2016, 12:00:14 am »
Hi
The ceramic bypass goes in parallel with the electrolytic. Ceramic does better at high frequency than electrolytic.
Bob
