Author Topic: TSOP48 in circuit test  (Read 3945 times)
Offline orion242
« on: October 10, 2014, 12:35:54 am »
So what are my options to connect up to a TSOP48 package on board?  I want to be able to test and possibly write flash in circuit.
Something like this.
http://www.deltadesign.us/
Is there anything in the hundred(ish) $ range or is the sky the limit.  This would be low volume use.
Thanks in advance.
Offline Mr. OBrien
    • OBrien Video
Re: TSOP48 in circuit test
« Reply #1 on: October 11, 2014, 01:44:41 am »
http://www.adapters-plus.com/SOP-AND-TSOP-TEST-CLIPS/
http://www.tme.eu/en/katalog/?art=MIKROE-1303
I seems as though it might be worth designing your own.  :-X
Maybe if we had a better idea what it was for.
Offline orion242
« Reply #2 on: October 15, 2014, 12:30:29 am »
I have a few boards I suspect the firmware is corrupt on.  They have a MC68334 processor with a bit of flash hanging on it.  I was looking to try and reload the flash with a known working image and see what happens.  There is a header that is attached to the MC6800 debugging pins which look like they could be used with some software and cables that are ~$600-$1k.  I would rather not remove the flash of course, but $1k just to test out on a handful of units...
Just looking for options and rough cost.
Offline orion242
« Reply #4 on: October 16, 2014, 12:18:32 pm »
Yep that looks like it will do the trick.  For the money if it doesn't work I won't be too concerned.
Thanks!
Offline symbianas
  • Country: lt
« Reply #5 on: October 29, 2019, 02:38:08 pm »
Hi, sorry for resurrecting old post, but I am also looking for cheapest in circuit TSOP48 reader/writer, to read flash memory for fun for my own pleasure. Does any one know device and connector which could do that?
