Author Topic: Help identify the pressure sensor  (Read 1240 times)
Online daisizhouTopic starter
  • Country: cn
« on: March 27, 2021, 12:48:31 pm »
There are 3 pressure sensors on the test air pressure detector,I took a picture separately
NB1 Looks like Sensym 926 SZ75153,metal shell,There are three wires in the interface.
NB2 I only see MICRO SWITCH USA,Number is K042
NB3  I only see MICRO SWITCH USA,Number is J1238 8914
Someone may know that this is a Honeywell model,I try to contact Honeywell service personnel,But gives the answer as shown below
I probably know this is the equipment produced in 1989,Can be used for medical related,Test air or oxygen dry gas,Pressure and flow
I hope people who know can tell me the model or the model used in place of it,Or its successor model
« Last Edit: March 28, 2021, 12:02:06 am by daisizhou »
daisizhou#sina.com #=@
  • Country: cn
Re: Help identify the pressure sensor
« Reply #1 on: March 28, 2021, 12:04:14 am »
Help, friends who know their model please tell me, thank you
Offline amyk
« Reply #2 on: March 28, 2021, 03:27:29 am »
Look in here? https://archive.org/details/SenSym-Solid-StatePressureSensorsHandbook1994OCR
All custom products are assigned special part numbers, typically SZ#XXXX
Yours looks like LX18XXDZ series, but is a custom part.
The following users thanked this post: fzabkar
  • Country: cn
« Reply #3 on: March 28, 2021, 04:57:04 am »
Thanks for the help.
But I can’t open and browse this URLhttps://archive.org/details/SenSym-Solid-StatePressureSensorsHandbook1994OCR
I can't find the reason
  • Country: cn
« Reply #5 on: March 29, 2021, 04:14:29 am »
I'm very much obliged to you,Let me quickly find the model,It is indeed LX1820DZ
This is the voltage value corresponding to my actual test pressure
If you can help me find another 2 micro switches,That would be perfect
Thanks again for your help
« Last Edit: March 29, 2021, 04:16:05 am by daisizhou »
  • Country: cn
« Reply #6 on: March 29, 2021, 05:54:49 am »
I measured this air pressure module,I guess this sensor has no magnification function,It relies on an external operational amplifier circuit to amplify the output.This is the clue i know
Offline fzabkar
« Reply #7 on: March 29, 2021, 09:32:30 am »
Are NB2 and NB3 switches, or are they pressure sensors made by Micro Switch USA?
For example, here are two 3-pin Micro Switch pressure sensors, with signal conditioning (not yours):
https://pdf.dzsc.com/1PC/141PC01G_1077424.pdf
https://docs-emea.rs-online.com/webdocs/0025/0900766b80025ae3.pdf
The first sensor in this datasheet is a 4-pin Wheatstone bridge requiring an external constant current source:
https://stevenengineering.com/Tech_Support/PDFs/31PRSS.pdf
« Last Edit: March 29, 2021, 09:54:44 am by fzabkar »
  • Country: cn
« Reply #8 on: March 29, 2021, 10:07:47 am »
They are pressure sensors.But mark "micro switch" on the shell.
I checked the housing of this pressure sensor, the pictures are on NB2 and NB3
Did not see the exact specification model
I have viewed your PDF, but the shape is different.So I measured the entire circuit board, hoping to provide some clues
  • Country: cn
« Reply #9 on: March 29, 2021, 12:51:08 pm »
NB2, NB3 pressure sensor,They don’t seem to have a gain amplification function.Amplified by an external operational amplifier.
I guess it should be a bridge strain resistance
I hope to find its original record,Try to replace it or buy another model to replace it
Offline amyk
« Reply #10 on: March 29, 2021, 01:44:36 pm »
180PC series looks like a close match...
  • Country: cn
« Reply #11 on: March 29, 2021, 02:13:15 pm »
180PC series looks a lot like,But only 3 lines of output,NB2 and 3 are 4-wire output.I think it should be a differential signal
Offline fzabkar
« Reply #12 on: March 29, 2021, 05:41:13 pm »
Here is an application circuit for a pressure sensor using a current source for biasing the Wheatstone bridge:
https://www.notwired.co/datasheets/te/signal_conditioning_for_meas_pressure_sensors.pdf
This is the circuit I traced on a Western Digital hard drive with a 4-pin barometric pressure sensor:
        VCC
         ___                                                          +
      .-|___|--.                                     U25 /|           |
     _|        |__                                      /+|------.   .-.
    | '---||---'  |               Wheatstone  |         \-|--.   |   | |
    |     ||      |                  bridge   | pin3     \|  |   |   '-'
    |             |                          / \             |   | R19|
    |             |       R20               /   \            |   '----+
    |      /|U26  |      ___               |     |           |        |
    |     /-|-----+-----|___|---------.   .-.   .-.          |       .-.
    +----<  |            ___          |   | |   | |          |       | |
    |     \+|-----+-----|___|-----.   |   | |   | |          |    R49| |
   .-.          .-+-.     R28     |   |pin4|     | pin2      |        |
   | |          |   |             |   '----+  U7 +----.      |        |
   | | R113    .-.  |             |        |     |    |      |       ===
   '-'         | | --- C14        |       .-.   .-.   |      |       GND
    |       R37| | ---            |       | |   | |   |      |
    |   D5        |               |         \   /     |      |
    v            ===              |          \ /      |      |
                 GND              |           |pin1   |      |
 amplified                        |           |       |      |
 pressure                         |           |       |      |
  output                          |           '-------)------+
                                                            | | R56
                                                            GND
U25 is the current source while U26 is a differential amplifier.
« Last Edit: March 29, 2021, 05:46:02 pm by fzabkar »
