Author Topic: IC Identification  (Read 505 times)
Offline GonziniTopic starter
IC Identification
« on: March 16, 2023, 11:56:04 pm »
Hi guys.
Anyone know what U4 might be in the attached pics? I read A3901 which comes up as a dual full-bridge motor driver which doesn't seem to make sense in this application. Also the track layout doesn't stack up to be one of those from what i see. I know these IC's can be used for other applications, but just seems a bit out there.
Board is out of some music gear which the audio outputs  fail, its a common problem with them.
Its part of the power supply, looks like a split supply going by the PCB layout. You would think it would be a regulator or switching mosfet maybe.
Cheers
Offline amyk
Re: IC Identification
« Reply #1 on: March 17, 2023, 12:08:53 am »
The following users thanked this post: Gonzini
Offline fzabkar
« Reply #3 on: March 17, 2023, 05:26:31 pm »
Cheers guys, makes sense now :)
That was exactly what i was expecting it to be. I'm not used to these devices so a bit hard to track the full part No. down if you don't know!
