No I haven't. Part of the reason is that my apparently flawed logic keeps pointing me back to the very low PLL/VCO voltage on the UHF board (3.2V vs 5.5V) that I can't adjust upwards. The supply voltage coming to the PLL/VCO is correct and by all right adjusting the coil inside the PLL/VCO, I should?? be able to increase the voltage but no matter where I adjust that coil, nothing happens. The 3.2V reading just stays the same. If my assumption is wrong can someone let me know (if the voltage to the PLL/VCO is too low (I think 2 volts low would be considered too low) than there is no way for the PLL/VCO to lock up. If I don't get lock up I don't think the radio can either receive or transmit. If I am wrong (not an unusual occurrence lately), then I need to look for the problem elsewhere. In case you are just joining this post, the VHF side of the radio is fully functional and in fact it's output power meets and exceeds the specs stated for the radio. The UHF side does everything it should in terms of memory allocation and recall, offset settings, tone squelch, power output adjustment, and manually opening and closing the squelch (so the receiver is not totally dead I do get speaker hiss), but feeding it a UHF signal does nothing and nor does keying up the mic (which works on VHF) does nothing.
