Author Topic: ID of this 3-pin SMD semi?  (Read 1261 times)
Offline EHTTopic starter
« on: March 02, 2022, 11:42:18 pm »
In process of debugging this PSU I'm wondering what this IC designated A4 in the attached pic is.
It is a small SMD with 3-pins and a tab. It is labelled "4A" above the line to the tab and "7J3" below the line. I'm not sure what this case style is called - maybe SOT89 - about 4mm wide.
The tab is connected to the centre pin, and in the circuit this is connected to GND. The label suggests it is an IC (D, ZD, Q etc for diodes and transistors). I thought it might be a voltage reg but it doesn't have stable DC on either pin (could be a fault). I've been able to identify most other ICs and larger semiconductors in this unit and they're not that unusual. It dates back to about 2009.
Offline gamalot
  • Correct my English
    • Youtube
Re: ID of this 3-pin SMD semi?
« Reply #1 on: March 03, 2022, 12:30:52 am »
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
The following users thanked this post: EHT
« Reply #2 on: March 03, 2022, 11:29:15 am »
Excellent, thank you very much! It makes sense given where it is too.
I wonder also if its possible to identify small SMD diodes and transistors that just have a 2 character marking, maybe there's a reference that helps, or is it just experience!!??
Offline gamalot
    • Youtube
« Reply #3 on: March 03, 2022, 11:47:32 am »
Identifying an SMD is often easy, but sometimes you may need the right resources, experience, and a little luck. I usually use google and those SMD code look up sites (eg https://smd.yooneed.one), and I also use taobao.com to search because I speak Chinese.
Just upload pictures of devices you can't identify, there's always someone willing to help.
Offline abdulbadii
Offline fzabkar
