Author Topic: ID of this SOT23-6 level shifter in SP511e LED controller?  (Read 534 times)
Offline GnatGoSplatTopic starter
« on: March 14, 2023, 03:14:38 pm »
Tinkering around with my SP511e LED controller flashed to WLED, I seem to have managed to bust a pin off the GPIO level shifter IC which rendered it dead.
I have since bypassed it and it still works without level shifting, but I would just like to know IF I were to repair it, what level shifter is this?
Here is an image showing it (not my SP511e, but you can see people like to hack these):
1738565-0
The level shifter IC appears to be SOT23 6-pin, has "245" marking on top.  Probably not a date code, because they all say "245".
Assuming dot denotes pin 1, pinout is as follows:
1 - output (shorted to 3)
2 - gnd
3 - output (shorted to 1)
4 - input (shorted to 5)
5 - input (shorted to 4)
6 - +5V supply
It converts 3.3V logic to 5V.  It appears to be single-supply, either single input and output or maybe they paralleled a 2-channel IC.  Driving LED strip data bus, so likely unidirectional.  Label on the PCB is "U4".
Any ideas?  AI (both Bing and ChatGPT) are absolutely no help at all.
Shawn
Offline fzabkar
Re: ID of this SOT23-6 level shifter in SP511e LED controller?
« Reply #1 on: March 15, 2023, 02:05:24 am »
I wouldn't call it a level shifter. To me it looks more like a dual non-inverting buffer (possibly a Schmitt trigger?). A genuine level shifter would have two supplies.
TI has a couple of devices which might do the job, but their Vcc is on pin #5.
« Last Edit: March 15, 2023, 02:08:03 am by fzabkar »
Offline Peabody
« Reply #2 on: March 15, 2023, 02:45:37 am »
It would probably be a single  gate version of some 74xx245 part - HC, AHCT, LVC, or something like that.  Maybe this one:
https://www.ti.com/lit/ds/symlink/sn74lvc1t45.pdf
« Last Edit: March 15, 2023, 02:50:01 am by Peabody »
Offline fzabkar
« Reply #3 on: March 15, 2023, 03:54:07 am »
The pinout doesn't match.
« Reply #4 on: March 16, 2023, 02:36:47 pm »
Yeah, I can't seem to find anything with a matching pinout.  I can't imagine they would have gone to the trouble to make a custom part.  :-//
Shawn
