While recently repairing some Keysight equipment built 5+ years ago with unleaded processes, I ran into residue, both clear and white crystalline in appearance, that will not respond to ANY solvent or flux remover.
In the past I've used MG Chemicals heavy duty flux remover and in some cases, one or more brake cleaners for spot issues.
While the clear flux residue from no-clean and unleaded will respond after keeping it damp and significant rubbing, I also ran into white residue, crystalline in appearance, which does not respond to rubbing at all. It had responded to a wooden stick end plus q-tip with remover, but the latest didn't even budge.
Simple solution to all of this ... with a rosin flux pen, put a light coating of flux over the clear residue, white residue and this hard white residue. With hot air tool set to 200C, played it back and forth over the new flux with some gentle rubbing from the wood stick end. Not enough heat to melt anything, including leaded as well. Only remained for maybe 20 sec. or so on a multi layer, heavily planed board.
A simple wipe up with clean remover and a q-tip took off everything !
Board is now pristine in appearance without any elbow grease.
