On the right side of the board shown on the picture below is a column of eleven pretty large SMD capacitors (located above and below the label "AOS 6930"). I've tried to google for SMD capacitors along with the label "100 C99" but haven't found anything that looks like those. Can anyone tell if those are 100µF tantalums or something else? (the SMD tantalums I know are usually yellow) What is the name of the form factor and is there any way to tell what voltage those are rated for?
