Author Topic: Identify 10 pin SMD ic “406R SNAB”...  (Read 695 times)
Online peteb2Topic starter
« on: June 28, 2020, 06:59:47 am »
Has anybody met this device please? It’s a 10pin device with what appears to be its output driving the Gate on an N-chnl HAT2198 MOSFET ‘switch’ via a 330ohm resistor.
It’s part of buck-boost circuit, the HAT2198 switching a DC voltage to another stage.  I’m trying to back engineer the board to discover why all of a sudden, the main ic  (LTM4609Y regulator) goes screaming HOT ...
Google has not thrown up anything in the way of a datasheet and 406R is a search beacon for a resistor! TIA
« Last Edit: June 28, 2020, 07:02:27 am by peteb2 »
Online PA0PBZ
« Last Edit: June 28, 2020, 09:10:34 am by PA0PBZ »
The following users thanked this post: peteb2
