Author Topic: Identify ALPS encoder  (Read 1354 times)
Offline DaxxinTopic starter
« on: April 19, 2020, 07:33:53 am »
hi , help me pls to identify this ALPS encoder
Offline MarkF
Re: Identify ALPS encoder
« Reply #1 on: April 19, 2020, 05:58:44 pm »
You didn't provide any dimensions???
It might be a Alps EC11 or Alps EC12.
I have been using PEC11 encoders in my projects.
Offline wraper
  • Country: lv
« Reply #2 on: April 19, 2020, 06:05:30 pm »
I suggest taking it apart and count number of detents if they are present and number of contacts to get pulse number per turn. Then select replacement accordingly.
« Last Edit: April 19, 2020, 06:07:33 pm by wraper »
« Reply #3 on: April 19, 2020, 06:31:04 pm »
Thanks for quickly help, here the inside pic visible detents , 3 contacts , for sure EC12 the shaft is plastic.
« Last Edit: April 19, 2020, 06:35:35 pm by Daxxin »
Offline wraper
  • Country: lv
« Reply #4 on: April 19, 2020, 06:37:47 pm »
Seems like 24 pulses, can you take out wiper part to see if there are any detents underneath? On second thought looks like there are none.
