Hi all, I am trying to fix an Advantest R3463 SA ( see
https://www.eevblog.com/forum/repair/advantest-r3463-trouble/msg4463401/#msg4463401 ),
I don't know if I have correctly identified the voltage rating of this capacitor:
the size is diameter = 6,5 mm high = 6 mm.
I think 47uF ok, but voltage 16 or 25 v?
There are others same size marked 33 ( ok 33 uF) EBH 7J5.
I searched on Chemicon, Nichicon and Wurth but nobody as a similar marklike these ( these capacitors are > 20 years old) .
Thanks and happy new year to all by Maurizio
