Author Topic: Identify Components by SMD code  (Read 1123 times)
Offline WilkseyTopic starter
« on: January 13, 2022, 06:08:06 pm »
Can anybody help identify the 2 components in the picture?
One has what looks to be 731 B34 and looks like the On Semi logo, the other looks like is has 73 4A, I am presuming these are diodes as they go across the VCC + GND points.
I think the large one is a zener of some kind and the smaller one is a TVS perhaps, the power comes in (3V3 or 5V) goes to a fuse, then passes by these and then connects to a E2PROM chip, standard 8KByte Microchip 25LC641.
Cheers
Offline fzabkar
Re: Identify Components by SMD code
« Reply #1 on: January 13, 2022, 06:20:11 pm »
"B34" could be a Schottky rectifier:
https://www.onsemi.com/pdf/datasheet/mbrs340t3-d.pdf
http://www.smdmark.com/en-US/search/code?id=B34
I expect that "4A" would be a 5V TVS diode.
The former would provide reverse polarity protection while the latter would handle overvoltages.
« Last Edit: January 13, 2022, 06:27:28 pm by fzabkar »
Offline gamalot
  • Correct my English
    • Youtube
« Reply #2 on: January 13, 2022, 07:10:56 pm »
The one in the SMA package should be a 5.6V Zener diode 1SMA4734A.
https://html.alldatasheet.net/html-marking/1296757/LEIDITECH/1SMA4734A/1143/2/1SMA4734A.html
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Offline fzabkar
« Reply #3 on: January 13, 2022, 11:11:21 pm »
Offline whatboy
  • Country: mx
« Reply #4 on: January 14, 2022, 12:41:01 am »
« Reply #5 on: January 14, 2022, 02:18:09 am »
Thanks for all of your replies,
I looked at a SMD code table but it didn't make sense for "4A" to be a 2V zener, but I did find another reference to a TVS with 4A markings.
The larger one could well be a schottky diode, I don't get continuity through either of the diodes in either direction, which made the think it is not a simple diode.
I have since discovered that VCC also goes into a TVS diode as part of a chip like this: https://www.diodes.com/assets/Datasheets/ds31271.pdf
Would there be 2 TVS diodes on the VCC line?
I have seen a picture of another similar circuit which has a large black diode and that part number actually shows it as a 5.6V 3W zener, but I can't see one with B34 markings.
Offline fzabkar
« Reply #6 on: January 14, 2022, 03:27:06 am »
« Reply #7 on: January 14, 2022, 11:56:45 am »
Yes, the more I look at it the more I am convinced you are right with the Schottky barrier diode,
So do you think the smaller one "4A" is more likely to be a TVS or a zener?
Offline gamalot
    • Youtube
« Reply #8 on: January 14, 2022, 12:00:51 pm »
I think that "73" may be a date code.
This is what a 1SMA4738A looks like:
https://www.taobao.com/list/item/599114971429.htm?spm=a21wu.10013406.taglist-content.4.673b990byuSgrY
Zener diodes with this part number can come from many different manufacturers, and they don't necessarily have the same marking layout.
