I see the datasheet, after removing the chip it seems it's not the issue as the short remains. There are 4 caps that are shorted and if I connect external 5V to 5V rail, IT8987 ship overheats so it looks that is the fault. Probably not worth fixing this as if I am not mistaken this chip would need to be flashed before it could work.
