I wanted to share another version of the schematic for the 885/886, below.
I didn't do a detailed comparison to the schematics that have already been posted to this thread and uploaded to KO4BB, but it appears to be a more recent version.
One thing I did notice is a little section labeled "USB PORT". I have an 886 and it's not spec'd to have a USB port, but it's there! It's well hidden under a bar-code sticker, which is on top of a thin gray piece of stick-on plastic that exactly matches the case color, which is on top of a small piece of stick-on rubber. See photo.
Plugging in the USB, from linux dmesg:
usb 1-4.1: new full speed USB device number 13 using ehci_hcd
usb 1-4.1: New USB device found, idVendor=10c4, idProduct=ea60
usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-4.1: Product: CP2102 USB to UART Bridge Controller
usb 1-4.1: Manufacturer: Silicon Labs
usb 1-4.1: SerialNumber: 4080IJ1140
usb 1-4.1: configuration #1 chosen from 1 choice
USB Serial support registered for cp210x
cp210x 1-4.1:1.0: cp210x converter detected
usb 1-4.1: reset full speed USB device number 13 using ehci_hcd
usb 1-4.1: cp210x converter now attached to ttyUSB0
usbcore: registered new interface driver cp210x
cp210x: v0.09:Silicon Labs CP210x RS232 serial adaptor driver
The USB port works (9600/8/N). It appears to operate the same as their benchtop version of this meter, the 889B. You can find the commands and data formats documented in the 889B manual.
I never really thought much about the "Remote" label on the front of the meter. Maybe there's a problem with USB and they withdrew support for it, or maybe they didn't want it to encroach on 889B sales. Maybe it's not on all versions of the 886.
