Author Topic: Identify this chip TI 2C  (Read 994 times)
Offline tru3533Topic starter
  • Country: no
« on: August 26, 2019, 11:11:12 pm »
Hello,
I have a controller card with a blown power rail chip on it.
On one location it seem to power USB.
Marking on chip says TI 2C
pin 1-2 supply in
pin 5 gnd
pin 8 output
Do you know what chip this is?
Any help highly appreciated, thank you!
Br, Tom
Offline narkeleptk
    • Youtube
Re: Identify this chip TI 2C
« Reply #1 on: August 27, 2019, 01:08:09 am »
It seems a bit like this guy tho the pin-out doesn't match the bottom picture.
http://www.ti.com/lit/ds/symlink/tps2051c.pdf
« Last Edit: August 27, 2019, 01:13:40 am by narkeleptk »
The following users thanked this post: tru3533
  • Country: no
« Reply #2 on: August 27, 2019, 02:08:58 am »
Too bad, looked promising :)
I'ts an 8-Pin MSOP-PowerPAD at least  :)
Offline fzabkar
« Reply #3 on: August 27, 2019, 02:18:27 am »
The two locations appear to be for two different chips.  :-//
http://www.ti.com/packaging/docs/partlookup.tsp
The bottom line appears to be the part marking.
  • Country: no
« Reply #4 on: August 27, 2019, 02:59:52 am »
Thank you so much fzabkar! you are absolutely right.
TI 2C is manufacturer and date
USB chip is PXMI  as narkeleptk suggested
Blown chip is different
TI 2C
PA2?
included picture
  • Country: no
« Reply #5 on: August 27, 2019, 03:34:08 am »
PA2Q ?
TPS7A6633QDGNRQ1
What do you think?
« Last Edit: August 27, 2019, 03:53:12 am by tru3533 »
Offline fzabkar
« Reply #6 on: August 27, 2019, 04:19:11 am »
That looks OK to me.
