Author Topic: Identifying 24 Way PCB Header on Repair  (Read 1464 times)
Offline bookabooTopic starter
  • Country: ie
« on: May 05, 2017, 10:05:30 am »
I have a PCB with a damaged connector identical to the one in the photos attached.
Does anyone have any ideas as to the manufacturer or product range I should be searching for? It's from an old 1990s era Houchin generator.
Offline BreakingOhmsLaw
  • Certified solder fume addict
Re: Identifying 24 Way PCB Header on Repair
« Reply #1 on: May 05, 2017, 03:01:05 pm »
Can't really tell the spacing from the picture, but i suggest you measure the exact pin distance and gauge with a caliper.
If it's a clean millimeter value, instead of 2/10 inch, then you can at least rule out US/UK manufacturers and narrow your search on european brands.
« Last Edit: May 05, 2017, 03:14:55 pm by BreakingOhmsLaw »
Offline Monkeh
The following users thanked this post: bookaboo
  • Country: ie
« Reply #3 on: May 05, 2017, 05:45:30 pm »
Thanks, that's saved me hours probably!!!  :)
Offline Monkeh
« Reply #4 on: May 05, 2017, 05:52:55 pm »
It took about 2 minutes to find :P
