Author Topic: Identifying 70's (?) through-hole components  (Read 7276 times)
Offline l0rd_hexTopic starter
  • I'm a master of karate and friendship for everyone
« on: October 25, 2015, 08:03:56 pm »
Hi friends,
Long time lurker, first time poster here.
The department I do IT work for has an old electron microscope which occasionally dies. The (EM) tech has kept a lot of the old bad boards and asked me the other day if I knew anything about diagnosing them (the small chat that arises when you want to borrow a multimeter!). I told him the furthest I've gone in diagnosing is checking voltages and resistances, he offered the contents of his drawer if I was curious anyways... and yup I'm hooked.
The boards are quite simple, single layer through hold construction kinda stuff. I'm stumped by a few of the components though, I've labelled them 1 and 2 on the picture. If anyone has an idea of what they are I'd love to hear  :)
The board it's self is a 24 power supply module.
Thanks!
Picture is here:
« Last Edit: October 25, 2015, 08:08:34 pm by l0rd_hex »
"I haven't paid taxes in six years, and I'm not getting busted by a damn sandwich." - Benjamin Franklin
Offline German_EE
Re: Identifying 70's (?) through-hole components
« Reply #1 on: October 25, 2015, 08:28:38 pm »
1) could be an MOV or a ceramic capacitor
2) Assuming it's the metal component is a power diode, they're made like that so that they can be slotted into heatsinks.
Warren Buffett
« Reply #2 on: October 25, 2015, 08:32:15 pm »
Thanks!
Yup, #2 is the metal can.
Offline Gyro
« Reply #3 on: October 25, 2015, 08:35:06 pm »
(1) is probably a thermistor, not sure if it's a PTC overload protector or an NTC inrush limiter. It looks to have had a hard life, as does some of the rest of the board. Worth checking for continuity.
(2) is a Top-Hat style diode, given the other conventionally packaged diodes on the board, I would think it's likely to be a 1.5W zener. The package markings should give an idea of voltage,
It's worth looking for and remaking cooked solder joints in the brown area. Check the two polyester caps above the transformer and the transistor next to them too. The electrolytics may be poorly at that age.
Hope it helps.
Best Regards, Chris
« Reply #4 on: October 25, 2015, 08:38:53 pm »
Will do, thanks for the hint about the caps!
I'll check these out this week and post back :)
Offline dacman
« Reply #5 on: October 26, 2015, 03:20:41 am »
I believe 1 is a thermistor also, and I would guess that it's an NTC inrush limiter (although that is just a guess).  It will test like a resistor with a DMM.
I've seen a lot of those diodes (marked with 2).  Doesn't it have a number on it somewhere?
I'd want a decent DMM and an LCR meter that uses a bridge to check out that board.
Offline Richard Crowley
  • KJ7YLK
« Reply #6 on: October 26, 2015, 03:47:25 am »
More curious:  What do you think is that long, slender, dark blue component between the top-hat diode and the blue electrolytic capacitor?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: October 26, 2015, 04:57:26 am »
Yeah, what they said ^^ :)
That, I have no idea.  It looks like a thin, unusually wonky reed relay!  Maybe a spark gap, but at that length, it'd be like 20kV, nowhere near what this circuit is doing  :-DD
As for overall circuit function, tempted to say it's an AC input (4 diodes, top left), filter (nearby electrolytics), NTC inrush, switching converter (probably blocking oscillator, flyback type -- derived from this sort of prototype http://seventransistorlabs.com/tmoranwms/Circuits_2010/Blocking_Oscillator.png ), and the rest of the board is output voltages, filtering and a feedback/regulator circuit, perhaps using an op-amp or regulator (the TO-99 ish can) IC.  Wouldn't seem to be isolated, at least, there's no obvious way to get feedback to the primary side without a common ground; also no isolation barrier.
« Last Edit: October 26, 2015, 05:02:07 am by T3sl4co1l »
Seven Transistor Labs, LLC
Offline oldway
« Reply #8 on: October 26, 2015, 07:29:50 am »
That's a low value resistance used as a shunt to measure current.
It's used in old Philips power suppllies.
Check it first because it often fails open  :--
1 is a NTC.
2 seems to be a BY100 or a zener diode.
« Last Edit: October 26, 2015, 07:32:01 am by oldway »
Offline tec5c
« Reply #9 on: October 26, 2015, 08:31:58 am »
Just out of curiosity, what is the board actually from?
As oldway said that the current shunt resistor is often used in Philips power supplies and you said that the board is the power supply module, are there any Philips markings?
Offline crispy_tofu
« Reply #10 on: October 26, 2015, 10:00:37 am »
Wow, those blob-shaped diodes (top left) look really funky!
+1, it looks like a riser board for something  :-+
Offline bktemp
« Reply #11 on: October 26, 2015, 10:12:36 am »
Those sinterglass diodes were fairly common in Europe for all kinds of high voltage stuff, maybe because they were mainly made by Philips and later by Vishay. Almost every BYxxx Diode had this or a similar package.
Offline tec5c
« Reply #12 on: October 26, 2015, 10:19:03 am »
On second look at the board, I'm almost certain it's from a Philips bit of gear.
Doubtful.
« Last Edit: October 26, 2015, 10:21:39 am by tec5c »
Offline HighVoltage
« Reply #13 on: October 26, 2015, 11:38:23 am »
Vishay is making high voltage diodes today, that look exactly the same.
And I think Vishay bought the resistor and diode factory from Philips Germany that was called Beyschlag before it became Vishay
Another indication, that this is a Philips made board and parts
Offline Gyro
« Reply #14 on: October 26, 2015, 12:08:24 pm »
It could actually be quite a high value wirewound resistor - I've seen those in up to around 10k in that long thin ceramic form in old gear. The value should be marked anyway.
Best Regards, Chris
Offline wiss
« Reply #15 on: October 26, 2015, 12:17:26 pm »
I harvested a bunch of switching 150-200 V diodes in this capsule resently. Unofortunately I also bought a bunch of 22 V zeners with the same capsule (new). Took me a while to figure out why my SMPS had so very low efficiency and the freewheeling diode got so damn hot! :)
Offline oldway
« Reply #16 on: October 26, 2015, 12:30:53 pm »
It is glass with a resistive wire inside, not ceramic.
Offline Gyro
« Reply #17 on: October 26, 2015, 12:35:15 pm »
Shall we settle on Vitreous Enamel?  :)
« Last Edit: October 26, 2015, 12:48:31 pm by Gyro »
Best Regards, Chris
« Reply #18 on: October 26, 2015, 02:58:29 pm »
Yup, this is marked "Philips" in solder mask on the back side. Good guess!  :clap:
Other than being from a Electron Microscope power supply I don't know it's exact function. The bag it was in said something about a 24V power supply.
EDIT: Done spelled sumthin' wrong
« Last Edit: October 26, 2015, 03:50:43 pm by l0rd_hex »
Offline oldway
« Reply #19 on: October 26, 2015, 03:02:17 pm »
I already replaced several broken ones, that's glass, not ceramic with vitreous enamel.
You see clearly on picture the solder glass/metal as on vacuum tubes.
« Reply #20 on: October 26, 2015, 03:21:30 pm »
It has some solder fingers on the left hand side (out of frame) that would fit into an ISA-esque socket.
EDIT: Fixed grammar + quote end tag
« Last Edit: October 26, 2015, 03:27:09 pm by l0rd_hex »
Offline FlyingHacker
  • You're Doing it Wrong
« Reply #21 on: October 26, 2015, 03:28:47 pm »
I have seen scinterglass diodes like those in the top left fail without any outward damage. Might be worth testing.
--73
Offline Gyro
« Reply #22 on: October 26, 2015, 07:00:42 pm »
Thanks for the clarification, I bow to your knowledge. I don't think I've ever come across one of those. All the long shiny ones I've seen have been very slim ceramic rod core with very fine resistance wire winding and an overall coat of vitreous enamel (as I say, up to quite high values). The only glass ones I have are vacuum encapsulated film 100M-10G types. I'm intrigued to know what benefit all glass construction would give (fragility sounds like one downside!), I would have thought differential thermal expansion (assuming solid glass) would be more trouble than it was worth.
I'll be on the lookout for one now.  :)
« Last Edit: October 26, 2015, 07:04:28 pm by Gyro »
Best Regards, Chris
« Reply #23 on: October 26, 2015, 08:17:05 pm »
All of your questions answered and more!
First off a huge Canadian style thanks to everyone who has commented, this is amazing.
Here's some values I measured:
Some other pictures of the board:
Offline Kjelt
« Reply #24 on: October 26, 2015, 08:44:14 pm »
If it is a 24V power supply for an electron microscope, that dept. has been integrated to the current company called FEI.
https://en.wikipedia.org/wiki/FEI_Company
« Last Edit: October 26, 2015, 08:48:37 pm by Kjelt »
Offline android
« Reply #25 on: October 26, 2015, 09:09:00 pm »
Just curious...what's with all the white "spacers" on the leads? I can understand having them on the power resistor for ventilation.
Lecturer: "There is no language in which a double positive implies a negative."
Student:  "Yeah...right."
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #26 on: October 26, 2015, 09:24:13 pm »
The spacers on the caps are likely to keep the bit of insulating coating that usually forms a meniscus on the leads that extends out a short distance from the body from reaching into the hole on the circuit board and by so doing potentially compromising the solder joint on that component.
-Pat
Offline Isad
  • Country: al
« Reply #27 on: October 26, 2015, 09:26:56 pm »
2: Seems like a 200v zener i have seen some like those and have
4 of them in my junk bin.
Lifes to Short Make the Most of It
My youtube channel: http://goo.gl/yMdPzQ
Offline dacman
« Reply #28 on: October 26, 2015, 09:34:51 pm »
The blue capacitors look like Philips (and I think I see Philips on one), which is now BC Components owned by Vishay.
Offline Gyro
« Reply #29 on: October 26, 2015, 10:40:39 pm »
If I read your latest picture correctly, one of the polyester capacitors (top right corner) is shorted! Not really surprising given the age and the temperature in that corner. That could be your fault right there. I'd suggest replacing both of them as a first step. They're fondly known as Philips 'Licorice All-sorts' capacitors. If I read them correctly, they are 100nF 10% (brown black, yellow, white). i can't see the bottom colour (voltage rating) in any of the pictures, this will be either brown (100V), Red (250V) or yellow (400V). It might be worth replacing them with polypropylene types for better ruggedness.
Edit: If you still get zero ohms across the PCB pads then it could be that the TO5 pkg transistor is shorted, but my bet would be on the capacitor itself.
« Last Edit: October 26, 2015, 10:43:58 pm by Gyro »
Best Regards, Chris
Offline T3sl4co1l
« Reply #30 on: October 27, 2015, 01:25:42 am »
I wouldn't be surprised if one of those caps is in parallel with a winding (to enhance resonance perhaps), but not if it's that big (1n or 10 would be reasonable, but 0.1u is kind of big for that).
Offline steve207a
« Reply #31 on: October 31, 2015, 06:31:11 pm »
well it looks like youve got ac from a transformer entering the board through the 4 small round diodes  with a couple of 150mfd smoothing capacitors then an inrush thermister  and the diode is possibly a zener to maintain a constant voltage and another smoothing cap check this one as close to heated parts and electrolytics have a habit of drying out over time and stress the 68 ohm resistor by 2 has seen some stress looks like a phillips type also the t05 transistor  spacer looks like its melted so that could be suspect having got so hot  the diode has some markings on it  if you remove it you should be able to see and look on internet for type /value the circuit  seems to go into the small transformer to supply the rest of the circuit look at the voltage spec on the blue cap next to the large diode as this may indicate the voltage for that circuit  so if 63volt then voltage around that part could  be 30 to 60v  just a guess but may help
regards steve
